Go to Post If they don't treat Dave nicely, he may just keep his big red ball, and not share with rest of us. - Barry Bonzack [more]
Unread 15-02-2013, 13:03
EskimoToast EskimoToast is offline
FRC #1710
EskimoToast is an unknown quantity at this point
Pneumatics Refilling
Hello,
I have a question regarding the refilling of pneumatics in the championship games, since the robot stays on the field between the matches, would we, or any other team with pneumatics, be able to bring an air compressor on the field and refill our tanks between the matches?
Unread 15-02-2013, 13:11
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: Pneumatics Refilling
Originally Posted by EskimoToast View Post
Hello,
The answer depends on how you fill your tanks. If you are running an offboard compressor then, yes you would be able to refill your tanks. If you are running an onboard compressor, then no you would need to fill your tanks with the compressor on your robot.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 15-02-2013, 13:50
funstuff's Avatar
funstuff funstuff is offline
AKA: Kat
FRC #4096 (Ctrl-Z)
funstuff has a spectacular aura aboutfunstuff has a spectacular aura about
Send a message via AIM to funstuff
Remember that your off-board compressor needs to be powered by the robot and meet the legal specifications of the compressor in <R80>
R80
Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not exceed nominal 12VDC, 1.05 cfm flow rate. Off-board compressors must be controlled and powered by the ROBOT.
2011-present | FRC 4096 | Technical/Mechanical Mentor
2006-2007 | FRC 624 | Electrical Subteam Captain, Strategist
2005-2006 | FRC 624 | Build Captain, Driver
2004-2005 | FRC 624 | Mechanical Subteam Captain, Driver
2003-2004 | FRC 624 | Driver
Unread 15-02-2013, 13:52
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
There is time between matches to reset your robot. You can either bring a compressor and your controls onto the field or you can remove your robot from the field and refill your bot.
5.5.6 TIMEOUT and BACKUP TEAM Rules
During the Elimination MATCHES, if circumstances require an ALLIANCE to play in back-to-back MATCHES, there will be a FIELD TIMEOUT to allow Teams to prepare for the next MATCH.
Unread 15-02-2013, 16:41
FRC #1710
Thank you everyone for your answers.
Edit:
Do you have to run code to fill the tanks as well? So that the robot is still powering the compressor to abide by the rules.
Unread 15-02-2013, 16:46
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Edit:
Yes it has to work exactly like an on-board compressor, except you take it off before a match to save some weight.
Unread 15-02-2013, 17:30
funstuff's Avatar
AKA: Kat
FRC #4096 (Ctrl-Z)
Yes, the robot would need to be powered up and running code to charge the compressor (use an old battery to fill your tanks, if you can).
Check out this thread on specifics of how you should be setting up an off-board compressor:
http://www.chiefdelphi.com/forums/sh...d.php?t=112133
Be sure to double check all of the rules - they indicate very well which parts need to be on the robot when your compressor is off-board.
Unread 15-02-2013, 17:48
FRC #1710
Ok thank you all for helping
