Go to Post The toughest regional is always the one you are competing in! - AcesPease [more]
Unread 15-02-2013, 20:04
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: cRIO Modules
Originally Posted by robohuskies2574 View Post
Our team is in need to change the default cRIO module locations in order for our intended plan to work, otherwise we have to slave away to move the locations of almost all of our electronics. For example, we want to move modules 9201 and 9403 from slots 1 and 2 to slots 7 and 8. Is it possible to change these modules' locations, if so how?
If you're using an 8 slot cRIO, you can define your components on (Analog/Digital/Solenoid) Module 2. You'll have to, however keep the same order of modules:
9201: Slot 1 or 5
9403: Slot 2 or 6
9472: Slot 3 or 7
