Go to Post The gearbox can be anything, just as long as it weighs less than 0 lbs, and yes, I'm talking about negative weight here. - NoodleKnight [more]
Unread 15-02-2013, 18:43
robohuskies2574 robohuskies2574 is offline
FRC #2574
robohuskies2574 is an unknown quantity at this point
Exclamation cRIO Modules
Our team is in need to change the default cRIO module locations in order for our intended plan to work, otherwise we have to slave away to move the locations of almost all of our electronics. For example, we want to move modules 9201 and 9403 from slots 1 and 2 to slots 7 and 8. Is it possible to change these modules' locations, if so how? Thanks.
By the way, we're using LabView.
Unread 15-02-2013, 18:45
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
ferret_guy is on a distinguished road
I don't think so if I understand correctly it is encoded in the fpga for generating pwm and safety protocol implmanation
Unread 15-02-2013, 20:04
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: cRIO Modules
If you're using an 8 slot cRIO, you can define your components on (Analog/Digital/Solenoid) Module 2. You'll have to, however keep the same order of modules:
9201: Slot 1 or 5
9403: Slot 2 or 6
9472: Slot 3 or 7
Unread 15-02-2013, 20:28
Re: cRIO Modules
9201: Slot 1 or 5
9403: Slot 2 or 6
9472: Slot 3 or 7
Except that R71 requires the 9201 in slot 1 and R64 requires that the 9403 in slot 2.
Unread 15-02-2013, 22:19
DonRotolo's Avatar
Back to humble
FRC #0832
Re: cRIO Modules
Is it possible to change these modules' locations?
Possible? Probably. Allowed for competition? Sorry, no.
