Go to Post Band geek FIRST geeks = uberparty! - Nuttyman54 [more]
Unread 02-15-2013, 09:15 PM
Gmercer Gmercer is offline
None #1631
Gmercer is an unknown quantity at this point
delays when sending commands to robot
We recently finished building our final robot build, but we're having problems with delays. We're about 8-15 feet away from the robot, and any command takes about .1 - .25 seconds to reach the robot. We didn't have a problem with our last robot build(as the code is almost the exact same), what could we have done to cause the delays on the robot now? my initial guesses
-Our router is in the middle of the robot, is it covered to much and has a delayed signal?
-What might i be doing in the operator control loop that could slow down the commands so badly?
Thanks for any help!
Unread 02-15-2013, 09:25 PM
Re: delays when sending commands to robot
Can the computer provide a detailed list of the differences?
