Go to Post Drive fast...drive true...otherwise it will kind of crush you - techhelpbb [more]
Unread 15-02-2013, 21:20
jnelly's Avatar
jnelly jnelly is offline
FRC #2472 (Centurions)
Team Role: Parent
jnelly can only hope to improve
Radio and CIM motors
If we place our radio only about a half inch from a CIM motor will we have issues with magnetic interference?
Unread 15-02-2013, 21:34
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Radio and CIM motors
Don't put it that close if you can help it. Especially after the FMS issues last year, you are strongly advised to put it up high, not near a motor, and not behind any pieces of metal.
Unread 15-02-2013, 22:15
DonRotolo's Avatar
Back to humble
FRC #0832
Not magnetic interference, but metal has this way of not letting radio waves through it. The antennas need to be not near metal. Find somewhere else if you can, like on a piece of something not-metal and flat, up higher on the robot, and mount it with velcro.
Unread 16-02-2013, 00:38
lior9999's Avatar
lior9999 lior9999 is offline
The Cleco Master!
AKA: Lior Ben-Yehoshua
FRC #4272 (Maverick Boiler Robotics)
lior9999 is just really nicelior9999 is just really nicelior9999 is just really nicelior9999 is just really nicelior9999 is just really nice
My team is mounting our wireless bridge inside of our electrical box at the bottom base of the robot (it's a rather tall machine). Do you think this could be an issue/cause us to have poor coms?
Unread 16-02-2013, 02:24
In a word: yes.
My advice is to keep it as high and exposed as you can without compromising the functionality of your 'bot and without risking having its wires snagged by other robots.
Unread 16-02-2013, 10:53
DonRotolo's Avatar
Back to humble
FRC #0832
Unless you have a non-metallic box and components (e.g., wires), yes.
Find some random space up high on the machine and velcro it there.
In past years we have lexan "sides" we use to display sponsor logos, we velcro it on the inside of one of those.
Unread 17-02-2013, 02:12
jmiller18 jmiller18 is offline
FRC #2429
jmiller18 is an unknown quantity at this point
A simple sheet of aluminum, even as thin as aluminum foil, wrapped around the cim will lower the emi to negligible amount
Unread 17-02-2013, 12:15
DonRotolo's Avatar
Back to humble
FRC #0832
Electrical, yes, but this has no effect upon magnetic, since aluminum is not a conductor of magnetism.
Unread 17-02-2013, 20:19
FRC #2429
Ok then just go to your local osh or hardware store and pick up some dryer tubing, which is as close to steel foil you can get and rap it around ur cims
Unread 17-02-2013, 20:24
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Which will be entirely saturated by the large magnetic field of the CIM because it's so thin. Notice how thick the flux rings are on the BaneBots motors.
All of that is beside the point, however, because a CIM is still a big hunk of metal that is going to block radio from the field. Save yourself a headache and just put the radio somewhere away from metal and motors where it'll get good reception.
Unread 21-02-2013, 07:06
While the CIMs are mostly steel the RFI from the brush assy. still will be emitted from the motor through the end bells and the wiring. Twisting the motor wires and making them short runs to the speed controllers helps a little.
The radio has two antennae, one on each side of the box. These are required for the 802.11 standard, they are not either/or (diversity). To insure maximum connectivity and throughput, your radio should be mounted away from surrounding metal of any kind and higher up in your robot. When metal is in close proximity to the sides of the radio, the antennae become detuned and output power is affected. When metal is close to the top, the same occurs. What you are trying to achieve is that the radio can 'see' the field antenna while you drive.
Unread 27-02-2013, 20:24
FRC #2429
also the routers use dipole antenna which use the electric field, not the magnetic, so that's all you need to block
Unread 27-02-2013, 21:27
The radio actually uses PIFA antennae, vertically polarized to the plane of the bottom of the AP. The circuit board is the ground plane.
Antenna actually have both electric and magnetic fields, but they are 90 degrees apart. Most discussions center around the magnetic field so the electric field lives in obscurity.
