Go to Post Some said the aluminum foil gave the robot a NASA-like quality, but others pointed out that blanketing components with a highly-conductive material that blocked air flow was probably not going to help get us to Einstein. - beerobber [more]
View Poll Results: What will your bot weight this year?
Antweight > 60 lbs 2 1.87%
Lightweight 60 - 80 lbs 4 3.74%
Middleweight 80-100 lbs 26 24.30%
Cruiserweight 100-100 lbs 33 30.84%
Heavyweight 110-120 lbs 34 31.78%
Sumo that needs a diet < 120 8 7.48%
Voters: 107. You may not vote on this poll
Unread 15-02-2013, 08:24
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Weight Poll
How is everyone doing with the annual weight battle. Did the smaller footprint help you make weight easier or did it not make a difference?
We are currently a tick under 80lbs and will probably finish a tick over. This will be our lightest robot ever beating out our Breakaway robot by about 15 pounds.
Unread 15-02-2013, 08:37
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Weight Poll
Can you really be between 100-100 lbs?
Unread 15-02-2013, 08:54
The_ShamWOW88's Avatar
The_ShamWOW88 The_ShamWOW88 is offline
Senior Mentor/Coach
FRC #0157 (Aztechs)
The_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to behold
Re: Weight Poll
We're right there at the max, we have about 8 pounds to play with after all is said and done which is actually a lot to have. Probably use it to spruce up the bot a bit.
"The best way to predict the future is design it"
"Striving for excellence through inspiration"
Unread 15-02-2013, 08:57
Andrew Lawrence
Posts: n/a
Re: Weight Poll
Middleweight for us.
And they said a robot made of steel would be heavy.
Unread 15-02-2013, 12:28
dbonar's Avatar
dbonar dbonar is offline
Nerd
FRC #3573 (Ohms)
dbonar is on a distinguished road
Re: Weight Poll
We'd love to go lightweight but we'll be closer to 90lbs.
Unread 15-02-2013, 12:33
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Re: Weight Poll
Haven't weighed it officially yet, but with everything but shooter (including motors) and electronics, we're at ~80 pounds. Probably going to go up to 100 with all electronics, motors, lighting, and any other stuff, but won't hold my breath. The rest of the weight we will have will be used for designing a climbing mechanism to attach on at week 1.
ERdit: Weight without electronics is 87 pounds.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 15-02-2013, 22:26
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Weight Poll
We are trying to find something cheap to use as 10-15 pounds of ballast so we aren't playing Lunacy on the carpet. Someone thought of a disconnected battery, but I nixed that one...
Unread 15-02-2013, 22:32
Best Available Data
FRC #1778 (Chill Out!)
Re: Weight Poll
Doesn't take a terrible large volume of steel to get up there. We used to get scraps of 1/4" steel plate from the local snowplow factory and stack it up.
We've got something like 40 lbs to play with (who knew a simple robot would be so light!), so some ballast is in order to move our CG to somewhere there isn't structure at 30".
Unread 15-02-2013, 22:49
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Weight Poll
We've found that the local sporting goods store sells barbells in very nicely marked sizes. Now you can prove while climbing the pyramid that your robot really lifts, bro.
Unread 15-02-2013, 22:51
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Re: Weight Poll
Assuming that cruiserweight is supposed to be 100-110lbs...that's about where we'll be weighing in.
Academic Student (Forever)
Unread 15-02-2013, 23:01
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: Weight Poll
75 pounds before climber here.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 15-02-2013, 23:03
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Re: Weight Poll
135 on a good day...
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 15-02-2013, 23:07
android1254's Avatar
android1254 android1254 is offline
FRC #1254 (Tech Force)
android1254 is an unknown quantity at this point
Cool Re: Weight Poll
well our team always seems to go big or go home were heavy weight 115 was our weigh in today. I'm just glad no Swiss chesseing needed this year.
Unread 15-02-2013, 23:30
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Re: Weight Poll
I think we've successfully built the smallest and lightest robot ever to play a match in FRC. As we packed it up for the Colorado scrimmage tomorrow we hung it from a fish scale. Without bumpers and battery it weighed a whopping 37 ilbs. It's designed to do just one thing-----CLIMB! The size goes hand in glove with the weight. It's frame perimeter is 78 inches (15 x 24). It has two motors, gearboxes and speed controllers and no they aren't connected to the wheels. If you're going to be at the Colorado scrimmage tomorrow come by and we'll show and tell.
