Go to Post We discovered this problem on the ship day (sure, when else?) - Manoel [more]
Unread 16-02-2013, 03:14
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Programming RGB lighting
Originally Posted by CooneyTech View Post
For the pwm which color goes where in the PWM(the red, green, and blue wire)? and where does the common wire go(the black wire)?
You will have to put each color onto a separate PWM output channel. Each color needs to be pulsed at a different frequency to generate different colors. The reason you have to pulse the wires to generate different colors is because the digital circuit only goes on or off, there is no in between value. So if you pulse on and off really quickly, you create the "average color" that is seen by the human eye. To achieve this, you should pulse at least 60 times per second, ideally at least 100, to make the colors look smooth.
For the remaining black wire, the wiring diagrams in the link above seem to have some units with this labeled positive, some are not labeled at all. Depending on whether the remaining wire is positive or negative will affect how you need to wire not only this wire, but also the signal amplifiers for the RGB lines.
But... check the control box that comes with these LED lights. See if there are any additional ports on this unit, such as a serial/UART, I2C, SPI, etc. Sometimes these RGB LED light sets have additional input ports, to allow an external controller to communicate directly to the unit to command it what to do. If this is the case, then it becomes simpler to implement it.
Art Dutra IV
世上无难事,只怕有心人.
Unread 16-02-2013, 09:53
CooneyTech CooneyTech is offline
FRC #0269
CooneyTech is an unknown quantity at this point
So for the pulsing how do I choose a color? Is it just the rate at which I pulse that particular color? I see what you mean be by on or off through my DIO blocks. I also understand hexadecimal through my web design class so that no issue for me.
Unread 16-02-2013, 21:03
artdutra04's Avatar
The duty cycle (the ratio of how much the output pin is on versus off) for the three RGB lines determines the output LED color.
Art Dutra IV
世上无难事,只怕有心人.
Unread 18-02-2013, 10:04
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
If the strip you are using is 4 wires RGB and Power/Ground, you cannot power it directly off the DSC you will need transistors because the DSC cannot handle that much current.
2015-2016 CSA
Software Engineering Student @ Johnson & Wales University
Team 228, Gus Robotics Inc.
Facebook
FLL Mentor for 1107, Edison Eagles!
2015- CT State Champions
2012- WPI Finalist(Thanks 1884 and 549), Spirt, Best Website
2011- WPI Chairman's award winners!
2010- WPI Champions! (thanks 230 & 20), WPI Engineering Inspiration, CT Best Website, CT VEX Champions (VRC228, VRC228b) (21-1-0)
2009- QCC VEX Champions (VRC228) (11-0-0), Innovate Award (VRC228)
Unread 18-02-2013, 11:16
FRC #0269
I talked to some mentors and we are going to power it off a DIO with some solid state relays.
Unread 18-02-2013, 13:32
FRC #0228 (Gus)
Solid state relays will not allow you to mix colors you would need transistors
SSR's only work on and off
2015-2016 CSA
Facebook
Unread 18-02-2013, 15:44
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
What do you think a solid-state relay is made out of? (power FETs, SCR's, Triacs, etc are all types of transistor.)
The LEDs intensity is controlled by PWM (Pulse Width Modulation) which IS an ON/OFF function.
They are on the right track here.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
