Go to Post I've got much more out of FIRST ever since I stopped and realized I can gain so much more from trying to improve my current team's situation rather than complain about teams who have more. - AdamHeard [more]
Unread 16-02-2013, 02:03
quando04's Avatar
quando04 quando04 is offline
Head Programmer - Robodogs
AKA: Quan Do
FRC #2579 (Robodogs)
quando04 is an unknown quantity at this point
Exclamation Robot doesn't function with this code
This is my first time using Java to program a robot. Our team has just finished putting together the robot and we tried to drive it today. The robot did not move a single inch. I am sure that the wiring are correct. There must be something wrong about this. I need some help on fixing this . Thanks!
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.DriverStationLCD;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SpeedController;
public class UltimateAscends extends IterativeRobot {
    //Declare Joysticks.
    private Joystick leftStick;
    private Joystick rightStick;
    private Joystick shootStick;
    //Declare Speed Controllers for Drive Motors.
    private SpeedController m_frontLeftMotor;
    private SpeedController m_rearLeftMotor;
    private SpeedController m_frontRightMotor;
    private SpeedController m_rearRightMotor;
    //Declare a RobotDrive.
    private RobotDrive drive;
    //Declare Pneumatics.
    private Compressor compressor;
    private DoubleSolenoid doublePiston;
    //Declare and initialize the Driver Station Output.
    private DriverStationLCD lcd = DriverStationLCD.getInstance();
     * Called once when the robot is first turned on.
    public void robotInit() {
        joystickInit(); //Joysticks initialized here.
        jaguarInit(); //Jaguars initialized here. Modify this if use Victors!!!!!!!!!!!!!
        robotDriveInit(); //RobotDrive initialized here. No need to modify this.
        invertMotor(); //Invert the motors if needed.
        startCompressor(); //Start the Compressor when the robot is turned on.
        getWatchdog().setExpiration(0.1); //The watchdog can be neglected for .1 seconds before it starves to death.
        lcd.println(DriverStationLCD.Line.kUser2, 1, "Enabled!     ");
        lcd.updateLCD();
     * Joysticks initialized here.
    public void joystickInit() {
        leftStick = new Joystick(1); //Left Joystick connected to port 1.
        rightStick = new Joystick(2); //Right Joystick connected to port 2.
        shootStick = new Joystick(3); //Shoot Joystick connected to port 3.
     * Jaguars initialized here. Modify this if use Victors!!!!!!!!!!!!!
    public void jaguarInit() {
        m_frontLeftMotor = new Jaguar(1); //Front Left Motor plugged in to PWM channel 1 on Digital Sidecar through a Jaguar.
        m_rearLeftMotor = new Jaguar(2); //Rear Left Motor plugged in to PWM channel 2 on Digital Sidecar through a Jaguar.
        m_frontRightMotor = new Jaguar(3); //Front Right Motor plugged in to PWM channel 3 on Digital Sidecar through a Jaguar.
        m_rearRightMotor = new Jaguar(4); //Rear Right Motor plugged in to PWM channel 4 on Digital Sidecar through a Jaguar.
     * RobotDrive initialized here. No need to modify this.
    public void robotDriveInit() {
        drive = new RobotDrive(m_frontLeftMotor, m_rearLeftMotor, m_frontRightMotor, m_rearRightMotor);
     * Invert the motors if needed.
    public void invertMotor() {
        drive.setInvertedMotor(RobotDrive.MotorType.kFrontLeft, false); //The Front Left Motor is not inverted.
        drive.setInvertedMotor(RobotDrive.MotorType.kFrontRight, false); //The Rear Left Motor is not inverted.
        drive.setInvertedMotor(RobotDrive.MotorType.kRearLeft, false); //The Front Right Motor is not inverted.
        drive.setInvertedMotor(RobotDrive.MotorType.kRearRight, false); //The Rear Right Motor is not inverted.
     * Initialize the compressor, pistons and relay and start the compressor
     * when the robot is turned on.
    public void startCompressor() {
        compressor = new Compressor(1, 1); //The pressure switch is attached to GPIO channel 1. The compressor relay is attached to relay channel 1
        doublePiston = new DoubleSolenoid(1, 2); //the forward piston is attached to channel 1 and the reverse piston is attached to channel 2 on the Solenoid Breakout.
        compressor.start(); //Start the compressor.
        lcd.println(DriverStationLCD.Line.kUser3, 1, "The Compressor is started!     ");
        lcd.updateLCD();
    public void disabledInit() {
        lcd.println(DriverStationLCD.Line.kUser2, 1, "Disabled!     ");
        lcd.updateLCD();
    public void disabledContinuous() {
        //Do nothing.
    public void disabledPeriodic() {
        //Do nothing.
    public void autonomousInit() {
        getWatchdog().setEnabled(false); //Disables the watchdog for the entire Autonomous period.
        lcd.println(DriverStationLCD.Line.kUser2, 1, "Autonomous!     ");
        lcd.updateLCD();
     * This function is called once each time the robot enters autonomous mode.
    public void autonomousContinuous() {
        while (isAutonomous() && isEnabled()) {
            //Add Autonomous Code Here!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    public void autonomousPeriodic() {
        //Do nothing.
    public void teleopInit() {
        getWatchdog().setEnabled(true); //Enables the watchdog for the entire Teleoperated period.
        lcd.println(DriverStationLCD.Line.kUser2, 1, "Teleop!     ");
        lcd.updateLCD();
     * This function is called once each time the robot enters operator control.
    long x = 1;
    public void teleopContinuous() {
        while (isOperatorControl() && isEnabled()) {
            //Drives the robot holonomically using joysticks for teleop.
            drive.mecanumDrive_Polar(leftStick.getMagnitude(), leftStick.getDirectionDegrees(), rightStick.getX());
            //Pushes the pistons forward using button 1 and backward using button 2 on the Shoot Stick.
            if (shootStick.getRawButton(1)) {
                doublePiston.set(DoubleSolenoid.Value.kForward); //Botton 1 of the Shoot Stick moves the pistons forward.
                lcd.println(DriverStationLCD.Line.kUser4, 1, "The Pistons are moving forward!     ");
                lcd.updateLCD();
            } else if (shootStick.getRawButton(2)) {
                doublePiston.set(DoubleSolenoid.Value.kReverse); //Button 2 of the Shoot Stick moves the pistons backward.
                lcd.println(DriverStationLCD.Line.kUser4, 1, "The Pistons are moving backward!     ");
                lcd.updateLCD();
            } else {
                doublePiston.set(DoubleSolenoid.Value.kOff); //The pistons does not do anything while no buttons on the Shhot Stick are pushed.
                lcd.println(DriverStationLCD.Line.kUser4, 1, "The Pistons are turned off!     ");
                lcd.updateLCD();
            //Stops the compressor using button 10 on the Shoot Stick.
            if (shootStick.getRawButton(10)) {
                compressor.stop();
                lcd.println(DriverStationLCD.Line.kUser3, 1, "The Compressor is stopped!     ");
                lcd.updateLCD();
            } else if (shootStick.getRawButton(11)) {
                compressor.start();
                lcd.updateLCD();
            } else {
                //Do nothing.
                continue;
            lcd.println(DriverStationLCD.Line.kUser5, 1, "" + x);
            lcd.updateLCD();
            x++;
    public void teleopPeriodic() {
        //Do nothing.
Quan
Unread 16-02-2013, 08:49
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: Robot doesn't function with this code
The continuous functions no longer exist as part of IterativeRobot. Your drive code should instead be in teleopPeriodic().
Also, don't use things like
This is only for if you're using SimpleRobot. In IterativeRobot, this loop is already made for you, and calls the init() and periodic() functions of each mode. If you put another loop inside of periodic(), your code may have serious delay issues.
I code stuff.
Unread 16-02-2013, 11:53
quando04's Avatar
AKA: Quan Do
Thank you!
Is that the only reason why my bot might not be moving?
Quan
