Go to Post The few people who don't ever make mistakes are the same people who simply don't do anything. What people do after they make a mistake tells others what they are made of. - Andy Baker [more]
Unread 16-02-2013, 09:29
gamegeek1995 gamegeek1995 is offline
FRC #4701
gamegeek1995 is an unknown quantity at this point
Side car 6V power light not on
For some reaon our side car's 6V power light is not lit up. Does anyone have ay suggestions on wat the problem could be.
Unread 16-02-2013, 09:57
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: Side car 6V power light not on
Check for shorts. We had a similar problem with the 5 volt light. Turns out a bolt had fallen onto the 5 volt digital outputs and was shorting. I'm not sure what on the sidecar uses 6 volts though so I don't have a direction to send you.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 16-02-2013, 10:37
DonRotolo's Avatar
Back to humble
FRC #0832
Disconnect everything (!) and turn the sidecar upside down so anything in it can fall out. Reconnect the power and 37 pin cable and see what you get. If OK, then connect things one at a time to see if it's one of those connections.
If not OK, verify 12 volts at the power connector, and try a different 37 pin cable and, if still NG, the sidecar may be faulty.
Unread 16-02-2013, 10:51
dman9385 dman9385 is offline
AKA: Dane Meyers
FRC #3098 (The Captains)
dman9385 will become famous soon enough
Send a message via AIM to dman9385 Send a message via Yahoo to dman9385
It's funny, We had a new DSC out of the bag, hooked it up and had power going in and out. It wasn't the wires so I took it apart and found the negative power leg had not been soldered to the board. We also found about 3 or 4 other leads had not been soldered as well. I fixed it, put it back together and runs perfectly now. Sounds like your's might have more than that issue though. Just putting my discovery out there.
2001 - 2003 - Driver/Student - Team 67
2004 - Drive Coach / Mentor - Team 406
2005 - Mentor - Team 1504
2006 - 2007 - Drive Coach - Team 1256
2008 - 2009 - Mentor - Team 1165
2010 - Present - Mentor/Scouting - Team 3098
