Go to Post I dont compete to win prizes, I compete to win Pride. - CircularLogic [more]
Unread 12-02-2012, 11:15
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Wiring Ring Light?
Originally Posted by wireties View Post
We can't do PoE, the bridge FIRST specifies is not PoE.
There are Power over Ethernet injectors that operate after the bridge.
Unread 12-02-2012, 11:34
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
PoE is 48V
Unread 12-02-2012, 18:47
cgmv123's Avatar
AKA: Max Vrany
PoE is 48V
There are extractors that will convert to 5v, 12v, and 24v all at once.
Unread 12-02-2012, 20:08
Right, but there are two problems to deal with for the application I was considering. First, I want to be able to turn the 12 volt circuit on and off under program control. Second, and rather more important at this time, is that every POE injector I've ever seen uses AC power from a wall outlet. Those are understandably rare on an FRC robot.
Unread 12-02-2012, 20:42
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The other problem is you will get the inspector that wants to know why you are not using the correct colors for power.
Unread 12-02-2012, 21:50
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
It is 48V at the input, where does that come from on a FIRST robot? So now one is taking 12V, bucking it up to 48V then "extracting" it (not a lossless process).
I like Alan's idea, to let +12V ride on unused pairs on a TP cable.
Unread 15-02-2012, 22:10
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Originally Posted by Alan Anderson View Post
What I'd really like to do is to get my hands on a supply of Ethernet jacks and mess around with tunneling power through a single patch cable from the electronics box to the camera, but that's not going to happen this year.
I've successfully powered the camera by patching into the unused pairs of an Ethernet cable near each end. It's not pretty, but if I can find some small panel-mount jacks I plan to try making an enclosure with two Ethernet jacks and four Anderson Powerpole connectors as a self-contained injector. The same device could be mounted at the other end to break out the connectors.
I've yet to test powering the ring light but will do that next.
Unread 16-02-2013, 11:21
Sargon2335 Sargon2335 is offline
FRC #2335
Sargon2335 is an unknown quantity at this point
My team is trying to hook up the ring light. I already have a terminal strip in place, but we do not know which side is positive and which is negative. I have looked on andymark, the vendor's website, and many different threads on chief delphi. Do you guys know which wire is which? I was assuming the one that is tinted copper is positive, but I don't want to plug it in until I know for sure.
Unread 16-02-2013, 11:40
LEDs are diodes. If you hook them up backwards, they won't turn on, but there won't be any damage.
Unread 16-02-2013, 11:47
FRC #2335
Cool, thanks.
