Go to Post I love the smell of burnt motors in the morning! - Mike Betts [more]
Unread 16-02-2013, 12:19
saberboy117 saberboy117 is offline
FRC #1870
saberboy117 is an unknown quantity at this point
Servo not responding
So our robot has a servo that we are trying to get working. Its hooked up to the PWM outputs on the digital side car next to our motors. No matter what we do it wont respond. Its not even powered! In labview I have it using the set angle function. Am I doing somthing wrong? such as when initalising the servo do I need to input the angle variable? Am I using the wrong function? is it pluged in wrong? When I use the same PWM port on a motor it works fine. Any ideas?
Unread 16-02-2013, 12:25
Re: Servo not responding
1) Are you using a 3-wire PWM cable (i.e., is there a 3pin connector at each end, and is the center red wire connected to the middle pin at each end)?
2) Do you have the power jumper in place to provide power on the middle pin for the servo?
3) You aren't trying to lift a hundred pounds with that servo, are you?
Unread 16-02-2013, 12:29
FRC #1870
no weight is on the servo, we just want it to turn.
We have a 3 pin pwm just like the motors use
Whats a power jumper?
Unread 16-02-2013, 12:33
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
akash992391 is on a distinguished road
this are jumpers u put on digital side car two pins and let me see your labview code..
Unread 16-02-2013, 12:42
FRC #1870
Jumper was the only problem. servo functions now. What about the max angle on servo initialization thou? Also what values does the servo range from, 0-1?
