Go to Post You want to be treated like a professional, so you need to continue to act like one even if the odds are against you. - Eugenia Gabrielov [more]
Unread 13-02-2013, 23:02
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Java, WPI, Image Processing, and OMG I got a memory leak...
I created the targeting code for our robot today. Everything was working great until about 20 seconds in ... WHAM! Out of memory... I'm pretty sure I freed both the BinaryImage I used and the ColorImage I used correctly. Please don't tell me this is a memory leak in the WPILibJ because targeting will be impossible since all the code is precompiled for Java and would be extra-tricky to change.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 14-02-2013, 06:06
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: Java, WPI, Image Processing, and OMG I got a memory leak...
You may not be running into a memory leak, but instead memory fragmentation. To minimize the number of (re)allocations done, you can try something like this:
// Inside the class, outside of any methods
Image image = new RGBImage();
BinaryImage bin = new BinaryImage();
Then later:
camera.getImage(image);
NIVision.colorThreshold(bin.image, image.image, ... );
// Other processing ...
I code stuff.
Unread 14-02-2013, 10:03
AKA: Spencer Lanman
Thank you for a positive response, Ill try this when Im with the robot next. I am curious though, is this how you do your targeting?
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 14-02-2013, 22:24
Ginto8's Avatar
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
I used that technique last year to minimize memory consumption, but this year our tracking software is running as a SmartDashboard extension.
I code stuff.
Unread 15-02-2013, 00:31
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Just a notice that the SmartDashboard v1.05 revision is up as of a few hours ago, and it solves several issues with the vision plugin.
I'm not sure if that would help you (it sounds like you're doing it robot-side?) but it may help others.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 15-02-2013, 07:53
AKA: Spencer Lanman
I don't want the delay of the data transfer, but thank you for that wonderful news. I hope it fixes the SmartDashboard crashing bug.
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 16-02-2013, 12:44
AKA: Spencer Lanman
What do I do about the exception handling?
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 16-02-2013, 17:54
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
try{
}catch(SomethingException ex){
ex.printStackTrace();
Unread 16-02-2013, 22:35
AKA: Spencer Lanman
You can't put try statements outside of a method. I found that simply creating the image objects outside of a method fixed my memory issues, I did not need to initialize them outside the method or call methods from NIVision. Thank you for the help Joe.
Shooter Operator
Catapult Operator
Chainsaw Operator
