Go to Post Programmer says autonomous will work 100% perfectly...Great way to clear the room of all mechanicals and all but the boldest electricals - EricH [more]
Unread 16-02-2013, 15:32
DCRich DCRich is offline
FRC #2180 (Zero Gravity)
DCRich is an unknown quantity at this point
How to determine cRIO2 slot addresses
How do I reset the slot addresses from a cRIO to a cRIO2? In the cRIO,
The NI models were setup in slots 1, 3, 5 and the demo codes would only work if the models were in those slots.
In the cRIO2 the modules are in slots 1, 2, 3.
So the DIO module has moved from Slot 3 to Slot2 but how has the address changed and how to tell the WPI library to look for the DIO in a different slot?
