Go to Post Excited and motivated students and teachers can do amazing things. - Wetzel [more]
Unread 16-02-2013, 16:16
Team 4457 Team 4457 is offline
FRC #4457
Team 4457 is an unknown quantity at this point
Parts of robot failing?
Hello, we are really scrambling to meat the bag date with a completed robot. right no our current problem is that the code we have written seems completely fine, but when it is run on the robot, certain parts don't work. When deployed from a different computer, we got a different set of parts to move, but is the exact same code. Any suggestions?
~There are always choices, some are just harder to make than others.~
Unread 16-02-2013, 16:29
jds2001 jds2001 is offline
AKA: Jon Stanley
FRC #4263 (CyberDrgaon)
jds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud of
Re: Parts of robot failing?
Generally, I'd say that you have electrical problems, not programming ones. Are all the connections from the digital sidecar to the various components secure? 99% of the time, these problems are electrical.
Unread 16-02-2013, 16:46
FRC #4457
Well, i am a programer, and i was told that everything is wired correctly.
Unread 16-02-2013, 17:18
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Which has nothing to do with whether it actually is wired correctly.
All opinions are my own.
Unread 16-02-2013, 18:00
FRC #4457
We just ran a test and only on side of the drive train was working (switching the PWM cables made neither work), two of our servo's work, but the third doesn't and it seems as if its code is being set to one of the servos that is working, as that servo tries to complete the action of the one that doesn't work.
Unread 16-02-2013, 18:30
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
If it's a code problem, you should be able to control everything from the LiveWindow (enable your robot in test mode with the SmartDashboard open). If that doesn't work then you have electrical issues or problems with your components.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 16-02-2013, 20:04
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
We just ran a test and only on side of the drive train was working (switching the PWM cables made neither work).
Sounds like a wiring fault to me.
KK4KQO
http://voltair.us
Unread 16-02-2013, 22:07
FRC #4457
Ok, so we reviewed the code and this is the result.
Working: One side of drive train; launcher; loader (one direction).
Not working: other side of drive train (runs in very short bursts, few and far between.); reverse on loader (sends to one of the two launcher motors, also in the short bursts).
Again, there are no visible problems with the wiring or code. We contacted our mentor team, but got no response. Thank you all for your help, and any possible solutions are welcome.
Unread 16-02-2013, 23:06
lorem3k's Avatar
lorem3k lorem3k is offline
1 + 1 = 0 (in Z/2Z)
AKA: Andy D.
FRC #1482 (Bishop Grandin Ghosts)
lorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to behold
Check the diagnostics tab on the Driver Station, and copy and paste the Messages field here.
Boo! Bishop Grandin High School / GM Canada / Tenaris
2013 Western Canada - Quarterfinalists (thanks 288/4719) / 2012 GTR West - Quarterfinalists (thanks 188/1075) / 2011 GTR East - Regional Winners (thanks 1114/1503)
Unread 16-02-2013, 23:12
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
First, are you using Labview, Java, or C++? Second, why don't you upload your code here for someone to look over?
Unread 17-02-2013, 02:26
If you don't know what the correct wiring is supposed to be, you'll never know that it's wrong unless you show it to someone who does know.
Here, the sporadic PWM outputs suggests to me that your Digital Sidecar might not be getting 12 volts from the Power Distribution Board. What do the three power LEDs on the sidecar look like -- are they all brightly lit, or is the BAT one dark? What pattern is the Robot Signal Light flashing when you enable the robot?
Unread 17-02-2013, 10:33
eedoga's Avatar
eedoga eedoga is offline
FRC #2980
eedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud of
Hey Alan,
I know you are feeling the pressure of only having two days left and having everything seem to fall apart...Been there myself as have most people here.
Electrical Engineers love to blame programmers for their problems. :-) To be honest you probably have a bit of both an electrical problem and a code problem.
Here is what I would suggest you do.
1) Change your battery for a freshly charged one. (You would be surprised how often magical problems go away when you do this.)
2) Go over your wiring really carefully. It is a rats nest in there and sometimes wires are connected to the wrong things by accident and "look" just fine.
3) Electronically go through system by system. So for example, pull all the PWM cables except for your drive motors. Then test your program for driving. Check that you have everything set right, and get that working first.
Also using a volt meter to see that you are actually getting voltage everywhere you expect it is probably a good thing.
Then slowly add back each subsystem doing the same thing.
4) Post all of your available information. Close up pictures of your wiring. Upload your program...Everything so that all the other teams you are asking for help can actually help you. Probably do step 4 first.
I wish you and your team the best of luck with this one. Remember...Even if you have to bag a non functioning robot there are plenty of teams that will help you at the competition. Teams have shown up with nothing but their kit of parts and left with a robot before...At the competition everyone wants to see your robot make it onto the field.
Good luck.
Edoga
Unread 18-02-2013, 16:01
FRC #4457
Ok, the program is attached, anyone that wants to review it/ make nessisary changes, you are welcome to. Ill work on getting that driver station error message and some pictures of the wiring. Ill also ask the engineers to run over there wiring with a fine tooth comb. thank you all very much for your help. By the way, we are using LabView.
Unread 18-02-2013, 17:18
FRC #4457
Here are the photos.
https://picasaweb.google.com/1097691...P-po2z67KNzQE#
Unread 19-02-2013, 19:46
FRC #4457
Ok, so we tested the robot again with a revised code.The right side of the robot dident run at all, and the pusher motor ran forward in those jumpy intervals as described before. Everything else ran fine. I have attached the revised code, and I will include the error message from the driver station. Thank you all for your help.
Watchdog Expiration: System 10, User 1
Watchdog Expiration: System 9, User 1
ERROR <Code> -44003 occurred at WPI_CameraIssue HTTP Request with Authentication.vi>>WPI_CameraIssue Get.vi>>WPI_CameraGet Image Appearance Property.vi>>WPI_CameraGet Color Enable.vi>>WPI_Camera Registry.vi>>WPI_CameraOpen.vi>>Begin.vi>>Robot Main.vi
<time>00:11:23 01/01/1970
FRC: Operation failed due to a communication failure with the camera.
ERROR <Code> -44003 occurred at WPI_CameraIssue HTTP Request with Authentication.vi>>WPI_CameraIssue Get.vi>>WPI_CameraSet Image Appearance Property.vi>>WPI_CameraSet Enum Appearance Property.vi>>WPI_CameraSet Image Size.vi>>Begin.vi>>Robot Main.vi
<time>00:01:57 01/01/1970ERROR <Code> -44036 occurred at WPI_PWMSetValue.vi>>WPI_MotorControlSetOutput.vi:5 >>Periodic Tasks.vi>>Robot Main.vi
<time>00:08:19 01/01/1970
Watchdog Expiration: System 8, User 0
Watchdog Expiration: System 7, User 0
Watchdog Expiration: System 5, User 0
Watchdog Expiration: System 3, User 0
Watchdog Expiration: System 2, User 0
<time>00:01:55 01/01/1970
WARNING <Code> 44007 occurred at FRC_NetworkCommunications <secondsSinceReboot> 25.468
Modified Network Configuration: Set
I/O unit not detected or not installed correctly.
