Go to Post I am not a poofologist... - Greg Marra [more]
Unread 16-02-2013, 16:37
gabrielc97's Avatar
gabrielc97 gabrielc97 is offline
AKA: Gabriel
FRC #4029 (Spartan Bots)
gabrielc97 is an unknown quantity at this point
Exclamation Robot communicating, but not functioning?
Our robot is about done. however, we ran into a problem. all of the wiring on our robot is corrrect, (we've checked over 5 times) our programming is all correct, ( we've also checked plenty of times) and the crio is reading our code and is recieving signal (we did several ping tests on the command prompt) our robot its self however, is not moving when we move the joysticks.
we dont know what else to do, so we hope that someone can help us out with any suggestions. thanks!
Gabriel
Unread 16-02-2013, 17:49
Re: Robot communicating, but not functioning?
Are you running the driver station, is the robot in teleop, and is it enabled? Does it show code running, an LED to the left on the driver station?
Greg McKaskle
Unread 16-02-2013, 18:38
gabrielc97's Avatar
AKA: Gabriel
yeah, im running the driver station. yes, its in teleop. and it is enabled.
all then lights except robot code is on. i try to load the code, but it says the Crio is not responding
i just loaded the code. but its still the same problem. all the LED's are on. and the Solenoids on our robot are responding. nothing is preforming its intended action.
Gabriel
Unread 17-02-2013, 01:59
There are three power indicator LEDs on the Digital Sidecar. Which ones are lit, and how brightly?
What pattern does the Robot Signal Light flash when you are trying to run the robot drive motors?
Unread 17-02-2013, 19:18
rhp3794 rhp3794 is offline
rhp3794 is an unknown quantity at this point
we have the same problem and while we are running the program theres a problem saying waiting the real time target to respond and the tree powers on the side card does not lit.
before we clicked enable after deploying the program the 5v led is functioning.
HELP PLEASE!!!!!!!!
Programming Leader
Team 3794
WinT
Unread 17-02-2013, 19:31
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
HELP PLEASE!!!!!!!!
If all three lights on the sidecar aren't lit, you should double check that the sidecar's power is wired according to this diagram. The power should come from the a terminal on the PDB that's protected by a 20 amp breaker
Unread 17-02-2013, 19:40
we have already changed the sidecard and the three lights are litting but while we are running the same problem of searching the real time target is not responding.
Programming Leader
Team 3794
WinT
Unread 17-02-2013, 23:11
BenGrapevine's Avatar
BenGrapevine BenGrapevine is offline
Head Programmer
AKA: Tony Simmering
FRC #2549 (Millerbots)
BenGrapevine is an unknown quantity at this point
Are you deploying code with the driver station open? Have you updated your cRIO firmware to the latest version? Is your network configured correctly? Are your joysticks set up and working? Did you do a hard reset after uploading code?
Millerbots Team 2549
orange and blue
Unread 18-02-2013, 07:15
yes i am deploying with driver station open, yes everything is updated including the driver station, our network is working correctly, our problem began yesterday on saturday we deployed and everything worked, and no there wasnt a hard reset.
inclusively i made a new project the problem with the real time target disappeared but when i clicked on enable nothing worked, the jaguars didnt turn green when i moved the joysticks on the x axis
Programming Leader
Team 3794
WinT
Unread 18-02-2013, 09:51
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
What OS are you using, i tried programming from windows 8 and had nothing but issues, i switched back to windows 7 on an older computer and all was well, i had the same issues as you,
2015-2016 CSA
Software Engineering Student @ Johnson & Wales University
Team 228, Gus Robotics Inc.
Facebook
FLL Mentor for 1107, Edison Eagles!
2015- CT State Champions
2012- WPI Finalist(Thanks 1884 and 549), Spirt, Best Website
2011- WPI Chairman's award winners!
2010- WPI Champions! (thanks 230 & 20), WPI Engineering Inspiration, CT Best Website, CT VEX Champions (VRC228, VRC228b) (21-1-0)
2009- QCC VEX Champions (VRC228) (11-0-0), Innovate Award (VRC228)
