Go to Post Our team's worst moment was the 13 years of FIRST's existence in which it did not exist. - Joe G. [more]
Unread 16-02-2013, 15:13
logic gates question
Could this be implemented in LabVIEW? And if so, what would it do?
note: the intent of the small circle on the bottom input of each AND gate is that the bottom input is inverted
Unread 16-02-2013, 16:16
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
It can be, I coded it up quickly while I was waiting for something, but I'm not sure what it is trying to do.
The second set of ANDs require the last output to be True, so unless you initialized the output to be true, the Ands would never let the code output True.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 16-02-2013, 17:16
Re: logic gates question
Unread 16-02-2013, 17:47
I wasn't sure who the question was for. Here is what it looks like in LV if you use the growable logic nodes.
I'll let others do the implementation to see the end result. There are many many ways to write this by the way.
Greg McKaskle
Unread 16-02-2013, 18:01
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Greg beat me with the exact implimentation for a toggle
Here is a simple one that has been posted before
Omar
Unread 16-02-2013, 18:25
Nirvash's Avatar
AKA: Bryan
FRC #4676
Ah, missed that first time I looked at it.
Unread 16-02-2013, 20:15
Attachment 14053
That's very concise.
@ Greg: how much different is the code that LabVIEW generates for the following two different approaches?
http://www.chiefdelphi.com/forums/at...3&d=1361055503
http://www.chiefdelphi.com/forums/at...8&d=1360772515
Unread 17-02-2013, 00:55
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Whoah, there are growable logic nodes? Time to go get rid of the 3 and statements I have hooked together...
I'm right 90% of the time, so why worry about the other 3%?
Unread 17-02-2013, 08:18
The LV compiler supports optimization transforms, but I don't expect there to be one that will turn the select and negate into the XOR. So I expect the XOR to be just a bit more efficient. I put the code into timing sequences and ran it 100,000,000 times and indeed, at least for intel code gen, the XOR is just a bit faster.
Greg McKaskle
Unread 17-02-2013, 16:44
Thanks Greg. I realize the difference, if any, is likely miniscule, but would it be reasonable to assume (based on your testing above) that the bottom sketch in the attached PNG is also slightly more efficient than the top one?
Name:	gt vs and.png
Unread 17-02-2013, 18:20
My testing showed that at least on Intel, the top one that used XOR was more efficient.
I rewrote the other to use a case statement instead of a select and it was then the fastest. Selects tend to execute both the true and false and then select the appropriate one whereas case statements will only execute one or the other.
But at this level for toggle on a button on a joystick, we are in the weeds. Write what is readable.
Greg McKaskle
Unread 17-02-2013, 18:33
Sorry, my previous post made no sense since I forgot to attach the PNG it was referencing. It's attached now:
http://www.chiefdelphi.com/forums/sh...5&postcount=10
Interesting. Thanks.
I agree 100%. My questions here are purely academic.
Unread 17-02-2013, 18:44
The > was a bit faster than the logic. This is again only on testing on intel and it was about 20% different.
Greg McKaskle
