Go to Post I have no clue. All I know is that every year the riddle in the clue has confused me but this year it is the lack of confusion that confuses me. - hallk [more]
Unread 16-02-2013, 12:51
Negative 9 Negative 9 is offline
FRC #0611
Negative 9 is an unknown quantity at this point
Using Spike Relays in Java?
Can anyone explain to me the best way to use Relays in code? The API confuses me. There are several ways to construct the relays and set them to values and I'm having trouble understanding the differences between them.
I'm trying to use a relay to control a window motor so from what I can tell I am supposed to construct the relay like this:
relay = new Relay(1, Relay.Direction.kBoth);
and I'm supposed to control the Relay by doing something like this:
if(joyRight.getRawButton(4)) {
	relay.set(Relay.Value.kON);
	relay.set(Relay.Direction.kForward);
} else if(joyRight.getRawButton(5)) {
	relay.set(Relay.Direction.kReverse);
} else {
	relay.set(Relay.Value.kOff);
If that's all good then the other possibility is that it's wired incorrectly. Does anyone know which section of the DigitalSidecar the triple wire is supposed to be plugged in? The diagnostic light on the Relay is a solid yellow-orange color which I assume mean that it's been initialized but isn't receiving any signals.
Any and all help is appreciated!
Unread 16-02-2013, 14:37
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Re: Using Spike Relays in Java?
The Relay is hooked up to the Relay section on the Digital Sidecar (With the LED Recess).
Orange Light beens it is receiving no signal (or the kOff signal) which means it is powered.
In my code I usually don't use the direction part, I stick to:
Relay relay = new Relay(1); //Constructor
relay.set(Relay.Value.kForward); //Power flows Positive to Negative, light green
relay.set(Relay.Value.kOff); //No power flows, light orange
relay.set(Relay.Value.kReverse); //Power flows Negative to Positive, light red
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 16-02-2013, 20:04
ClockworkPirate ClockworkPirate is offline
AKA: Mario Guerrieri
FRC #0670 (Homestead Robotics Team)
ClockworkPirate is an unknown quantity at this point
We have our relays wired what seems to be correctly (PWMs from relay area on the sidecar, orange light), and my code is exactly like yours (besides variable names ), but the relays won't do anything. No matter what I call set() with (I've tried all four Relay.Value values), the light stays orange. What am I doing wrong?
Unread 16-02-2013, 20:18
gixxy's Avatar
I would have to see your code in its entirety.
Unread 16-02-2013, 21:05
I have a field in my Shooter class with a field Relay pneuRelay, which I initialize in Shooter's constructor with pneuRelay = new Relay(1); (we have a relay plugged into the first plug on the sidecar). I call
public void setForward()
    pneuRelay.set(Relay.Value.kForward);
on it, nothing happens.
There is kind of a bunch of abstracted stuff down to that "real" call, but nothing happens even when I put the call (new Relay(1).set(Relay.Value.kForward)) right in the constructor of our SimpleRobot subclass... It seems to me that either I'm not using the library right or the relay isn't wired correctly.
Here's Pastebins of my code if you still want to see it (this is with the port 1 initialization in the SimpleRobot constructor, so the one in Shooter.java is changed to 2 to avoid a conflict):
Robot2013.java (SimpleRobot subclass)
DriveStation.java (has Shooter, DriveTrain, etc objects, interprets joystick controls)
Shooter.java (controls the shooter motors, I'm trying to add the relay to control some related pneumatics)
Unread 17-02-2013, 16:06
FRC #0611
Thanks, this got our code working!
