Go to Post By the end of week six, I'm sick of looking at the robot enough that stuffing it in a bag is rather cathartic...:rolleyes: - 2544HCRC [more]
Unread 16-02-2013, 19:57
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
akash992391 is on a distinguished road
Unhappy servo problem
can some one tell me, do i have to put 0 to 180 on servo angle or 0 to -1
i try everything to programmed function and everything but still not working can someone help me.....
Unread 16-02-2013, 20:06
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Re: servo problem
0 to 180 and make sure you have a jumper on the two pin connector next to the pmw of your choice.
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 16-02-2013, 20:12
AKA: Akash
FRC #4684
Re: servo problem
i tried 0 to 180 still doesent work
Unread 16-02-2013, 20:13
AKA: Garty
Re: servo problem
Do you have a jumper installed?
- Dr. Seuss
Unread 16-02-2013, 20:19
AKA: Akash
FRC #4684
Re: servo problem
yeah i did
Unread 16-02-2013, 20:22
AKA: Garty
Re: servo problem
Your code should look something like this.
- Dr. Seuss
Unread 16-02-2013, 20:24
AKA: Akash
FRC #4684
Re: servo problem
yes i do have same one...
Unread 16-02-2013, 20:26
AKA: Garty
Re: servo problem
Could you post your code?
- Dr. Seuss
Unread 16-02-2013, 20:32
Re: servo problem
You aren't trying to lift a 10 pound weight with that servo, are you ?
Unread 16-02-2013, 20:37
AKA: Akash
FRC #4684
Re: servo problem
no i m not lifting anything
Unread 16-02-2013, 20:39
Re: servo problem
Do you have a cheap digital voltmeter handy?
Unread 16-02-2013, 20:40
Re: servo problem
Does putting the Driver Station into Test Mode, and using the Dashboard Test tab, let you move the servo?
Unread 16-02-2013, 20:47
AKA: Akash
FRC #4684
Re: servo problem
here is a code
Unread 16-02-2013, 20:48
AKA: Akash
FRC #4684
Re: servo problem
yeah i do y
Unread 16-02-2013, 21:01
AKA: Garty
Re: servo problem
right now your two positions are using double numeric values when i believe they should be just numeric values. (Changes the orange numbers to blue numbers)
- Dr. Seuss
