Go to Post If it wasn't for 47, none of us would be here. - Taylor [more]
Unread 02-15-2013, 09:51 PM
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Controlling two subsystems with one controller
For out shooter and loading mechanism we are using a single xbox controller. It seems thought that if a single button activates a method that takes time to complete that any other method cannot interrupt when it is activated by a button that is on the same controller.
Is there any way to fix this?
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 02-16-2013, 07:35 PM
inkspell4's Avatar
Is each controller only able to have one command running that was activated by a single controller at a time.
Unread 02-16-2013, 08:22 PM
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Re: Controlling two subsystems with one controller
I was using three commands at once yesterday with an Xbox Controller. (Running Launch Motors with a While Held, Firing a piston using a timeout, and running a second motor with a while held). I know this is possible.
Our Code: https://github.com/frc3946/UltimateAscent
Are you using any Timer.delay()'s in your code? That would cause the entire robot thread to wait.
For further help please post your code.
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 02-16-2013, 08:47 PM
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is online now
Robotics Engineer
FRC #0319 (Big Bad Bob)
Controllers are just used to start/trigger commands. If you can't interrupt commands, then your commands must not be implemented correctly. Could you post the code for the command that cannot be interrupted?
Unread 02-16-2013, 09:03 PM
inkspell4's Avatar
To be more specific we are using whenPressed to control a subsystem for each of the bumpers on the controller each one activating a different subsystem.
When one is pressed and the method is running the other will not run. The second method is not linked to the first.
While this is going on the drive train still works although it is controlled by a separate set of joysticks.
