Go to Post *gasp* Robotics? bad for your health? I refuse to accept that as an answer. - Kiwi_queen [more]
Unread 16-02-2013, 22:10
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Re: Pre-Stop Build Scrimmages - What Have We Learned So Far?
Originally Posted by joelg236 View Post
Interesting. Do you think this would fall under G16? How could you tell if it was intentional or not? I guess its under the discretion of the refs, but it seems like this could be a pretty big factor, especially for teams who assume nothing will contact them while climbing.
You would be hitting your own robots, so i don't think G16 would apply.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 16-02-2013, 22:12
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Not sure how I didn't think about that.
All opinions are my own.
Unread 16-02-2013, 22:21
Samwaldo's Avatar
Samwaldo Samwaldo is offline
College Student / Between Teams
Samwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to behold
we were so worried that there wouldn't be enough Frisbee on the ground to pick up. our robot was built practically around the pick-up because we worked so hard and were so dedicated to picking up. After seeing webcasts we know that a pick up will for SURE work out and be beneficial! it took awhile for teams to drive and load to and from the feeding zone. also alot of missed shots and alot of human players throws made it look like it was snowing.
Lastly i saw a few teams angling their shooters extremely high and shooting into the 5pt goal right next to the pyramid. none went in.
Team 1099, The DiscoTechs, 10' - 14'
Driver 11' - 14'................Team Captain 13' - 14'
University of Hartford Class of 2018, Mechanical Engineer
2015 & 2016 NE District Volunteer
Unread 16-02-2013, 22:27
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Not true.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 16-02-2013, 22:32
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
A lot of things I saw today; Only 1 robot had a floor pickup mechanism and very rarely used it. The last 30 seconds there were quite a few Frisbees on the field & a frenzy of Frisbees flying everywhere from the HPers. The nets did have to be raised higher up to protect the scoring table. They will need to add additional netting at events on the ends to protect crowds & any audio/visual personnel & equipment. The net opening where teams enter/exit will have to be modified so robots don't catch the drooping netting. there were issues today & we came up with a temporary fix. FIRST has been made aware & hopefully will provide a solution for week 1. Numerous robots were able to rise to the 10 point level during the last 30 seconds.
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
Unread 16-02-2013, 22:43
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
One alliance in elims had all three at the 10-point level. It didn't win for them.
Shooting through the pyramid at the 6-point goal in auton. is quite a lead to make up. With an alliance partner also high % in that auton. goal makes an even better start. I was wondering if frisbee transfers during auton. would be possible as they were in RRumble.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 16-02-2013, 22:50
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Getting to the feeder station and back is very easy.
1058 PVC Pirates 2016 - xxxx
PVCpirate's Avatar
PVCpirate PVCpirate is offline
FRC Data Nerd
AKA: Anthony Jennings
PVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud of
I think it will be harder in this game because you can't roll frisbees to your partner like you could with basketballs. I suppose a shooter could spit their frisbees on the floor for partners to pick up, but I think that would be too unpredictable to pull off.
My accomplishments with 1058:
2010 - Granite State Regoinal Winners, Galileo quarterfinalists, IRI quarterfinalists
2012 - GSR Chairman's Award winners
An incredible four years I will never forget
Unread 16-02-2013, 22:52
PVCpirate's Avatar
FRC Data Nerd
I would say easy but slower than vacuuming up all the frisbees under the goal and scoring them .
Unread 16-02-2013, 22:54
AKA: Brendan Browne
One way to find out but you didn't come to Week Zero!
Unread 16-02-2013, 23:01
FRC #2170
Not if you had a determined and skilful interloper like 2168 in your way. Ask 177 how their trips to the feeder went during elims at Suffield. 177 made a lot of good shots on 3&6 goal but they had to (?) do it from a certain spot next to their pyramid.
Unread 16-02-2013, 23:25
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
From the webcast I saw of the later matches, 177 wasn't next to the pyramid, they were jammed up against the back edge of the pyramid.
Academic Student (Forever)
Unread 16-02-2013, 23:46
frasnow's Avatar
frasnow frasnow is offline
Software
frasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to behold
There will be some very effective feeder station shooters. One at the scrimmage I went to could make nearly every shot in the two point goal once it was lined up. And the driver was pretty good at getting it lined up.
Unread 16-02-2013, 23:51
FRC #2170
Whatever you call their location, 177 is usually worth watching. From their preferred position, I saw one disk that glanced off the pyramid bar. They backed up a little and the next two got them 6 points.
They were also sporting one side of "censored" tapes, presumably to add an air of mystery to their appearance. Then they took a spill and we saw England, we saw France, we saw Bobcats' underpants. With a "V" in the frame on that censored side, it's not too hard to surmise there will be a corner climber in 177's future.
177's human player has a hammer throw that got several 2-ptrs at blizzard time. Not sure, but he may have had double digit scoring in one match.
Unread 17-02-2013, 00:41
Moriarty's Avatar
Moriarty Moriarty is offline
AKA: Brendan Moriarty
FRC #4302 (Robophins)
Moriarty is a splendid one to beholdMoriarty is a splendid one to beholdMoriarty is a splendid one to beholdMoriarty is a splendid one to beholdMoriarty is a splendid one to beholdMoriarty is a splendid one to beholdMoriarty is a splendid one to behold
Originally Posted by Ian Curtis View Post
Reliable full court 3 pt shots are definitely a thing, and it will be fun to watch teams realize this on Thursday/Friday.
Are they accurate though? I knew from the beginning that they were possible, but are they a game breaker unless blocked? Are they accurate enough to be superior to a half court shooter with a fast drive train and extremely accurate shooting?
