Go to Post Quoting Fred Durst--"Bring it on." - Billfred [more]
Unread 16-02-2013, 23:49
Pirate King Pirate King is offline
Team Captain
FRC #0354 (Westinghouse Pirates)
Pirate King is an unknown quantity at this point
cRio slot 4 programming
My team has the 8-Slot cRio and we are planning on using a second Pneumatics Bumper module in the fourth slot. The only problem is that i just cannot get it to work. In java when it asks for the module number i put "4" and for the channel i put "1". Whenever i run this it get errors and the code does not run. How do i solve this problem?
Unread 16-02-2013, 23:56
Re: cRio slot 4 programming
The 4th Slot of an 8-slot cRIO is not used.
You need to put the second Solenoid Module in slot 7.
In Java, the second Solenoid Module is referenced as "2", not by the physical slot it is in.
  • Slot 1 - Analog module (required)
  • Slot 2 - Digital module (required)
  • Slot 3 - Solenoid module
  • Slot 4 - unused
  • Slot 5 - Analog module
  • Slot 6 - Digital module
  • Slot 7 - Solenoid module
  • Slot 8 - unused
Unread 17-02-2013, 00:08
Team Captain
Thanks! I'll try that out. By the way where did you get this information from?
Unread 17-02-2013, 08:59
It's from:
Wiring the 2013 FRC Control System
However, beware the column headers are switched.
It has cRIO FRC II then cRIO FRC, but the column underneath each one is really the listing for the other cRIO hardware version.
