Go to Post Mentors are here to guide and explain not to decide and do. - Fe_Will [more]
Unread 16-02-2013, 10:32
chriz4gx chriz4gx is offline
AKA: Christopher Villar
FRC #2871 (Beantown Botz)
chriz4gx is an unknown quantity at this point
Using VEX Ultrasonic Sensor
So I'm trying to use a VEX Ultrasonic Sensor(276-2155) But I'm having a difficult time trying to find the correct Labview Example that works with the VEX Ultrasonic Model. Where can I find an example? Also, when we program the Ultrasonic Sensor how would I get it that it sends information(about Distance) to the "User Messages" Text Box in the Driver Station and continuously updates it? Thanks
Unread 17-02-2013, 00:45
Re: Using VEX Ultrasonic Sensor
I don't think there's an example for that type of sensor. The way it works is not something that is supported directly by the WPI library. I'm not even sure anyone has figured out the proper wiring and counter configuration to get useful information from it. Hopefully someone will answer with advice you can use.
Use the "Write User Message" function in the WPI Driver Station function palette.
Unread 17-02-2013, 01:29
josneville's Avatar
josneville josneville is offline
The Chosen One
FRC #0540 (Talon 540)
josneville is on a distinguished road
Talking Re: Using VEX Ultrasonic Sensor
Most ultrasonic sensors are connected via the analog module of the CRIO. If that is true in your case, read the voltage from the analog channel and multiply it by 100 to get the distance from the sensor.
-Success is the Key to Life. I have no life. Hmmm......
Unread 18-02-2013, 10:02
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
There used to be a set of (horribly written) vis in WPIlib to support an ultrasonic encoder with two digital ping/response lines. I believe they still exist, but I'm not sure.
It used the DIO Pulse feature and DIO Interrupt features to generate and listen to a pulse. Unfortunately, it was written to Wait On Interrupt, causing the thread that called the ultrasonic sensor to hang until either a pulse was returned, or the timeout (60ms) was reached.
Unfortunately, the majority of the library is written synchronously with blocking calls like this, which is IMHO really really bad embedded code design.
The FPGA has a lot of rarely or never used features which I have never seen used, including these DIO pulse and interrupt features, and a lot of DMA capabilities.
Kettering Motorsports
