Go to Post I've always believed that being who I was will not limit me to who I will be. That's what keeps me trying to learn more and become a better person. Otherwise I would've settled being someone ordinary and not care about anything around my life. - Ken Leung [more]
Unread 16-02-2013, 16:11
rakesh3352 rakesh3352 is offline
FRC #3352
rakesh3352 is an unknown quantity at this point
Outputting distance on the dashboard
How do I output the computed distance from the camera on to the dash board?
Unread 17-02-2013, 01:28
Re: Outputting distance on the dashboard
On the robot, put the value into a SmartDashboard variable with a name you like. Use the SD Write Number function.
On the Dashboard, create a numeric indicator with its label set to the same name you chose before. On the front panel, place the indicator in the Operations tab along with the existing example checkboxes and slider. On the block diagram, it sits outside the main While loop, disconnected from everything else. The Dashboard program contains code that will automatically update the indicator from the SmartDashboard variable.
