Go to Post We had an over all losing record this year. When I look at kid's faces, they don't give a rip about that. I see excitement about the next event and talking about improvements for next year. Winning is nice, but that is not the reason I do what I do. - wilsonmw04 [more]
Unread 16-02-2013, 17:17
Re: Driverstation referencing
The variables tab shows the current value of every variable in all network tables along with metrics on its usage. If it shows the correct value, that indicates the writes are working and the issue is with the reads, otherwise the first issue to resolve is that the writes are not working.
Greg McKaskle
Unread 17-02-2013, 01:43
Originally Posted by CooneyTech View Post
On the left is teleop on the right is the dashboard reference.
I see them in the other order, but no matter.
Where are those wires heading upward in the dashboard code going, and what are they connected to? Is that part of the code inside a loop?
Unread 17-02-2013, 09:55
CooneyTech CooneyTech is offline
FRC #0269
CooneyTech is an unknown quantity at this point
It was a different test I did I was bundling them then trying to send them that way to. I have sense removed it and just did each one individually.
Unread 17-02-2013, 18:09
FRC #0269
Post Re: Driverstation referencing
Attached I have the driver station code and the code for Teleop where i reference it.
Unread 17-02-2013, 22:43
It looks like your Dashboard code does a SmartDashboard write for those values once when the program begins, then never does it again. If you want to use the SD Write functions, you'll need to put them in a loop that runs as long as the values are required.
But you don't need to use the SD functions with the LabVIEW Dashboard. An indicator or control on the Operations tab is automatically a SmartDashboard variable all by itself, and Greg showed you how to make things on other tabs work as well.
Unread 17-02-2013, 22:56
FRC #0269
If its a SD by its self how exactly do I reference it? And for a loop would a while loop work ok?
Unread 17-02-2013, 23:47
Most of the time, you would "reference" a SmartDashboard variable simply by looking at it on the Dashboard's front panel, or by clicking on it, or by typing a number in it.
A While loop is perfect. Just make sure to include a short delay (50 ms or so) to keep it from monopolizing the CPU.
Unread 19-02-2015, 13:42
DKolberg DKolberg is offline
Mentor Iron Giants
AKA: David Kolberg
FRC #5069 (Iron Giants)
DKolberg has a spectacular aura aboutDKolberg has a spectacular aura about
There isn't one built in that I've found. You'll need to unbundle the cluster and write each element separately, and you can bundle them back together at the other end if you want to. If you get fancy, I think you can use a name hierarchy, adding the cluster name and a slash in front of the element name, and get things to "cluster" together in the variable viewer.
You can use the flatten to/from string to send anything between robot and driver station. Just have to use correct constant type for the unflatten.
David Kolberg
2014- Mentor Iron Giants 5069
2004-2010 Coach SBotz Team 1327
2000-2003 Mentor Team 135
2016 St. Joe District Event Winner
2009 WFA Boilermaker
2008 Driving Tomorrow's Technology
2005 Innovation in Control
2005 IRI Spirit of Indiana
