Go to Post Brandon Martus, making CD readers' lives easier since May 2001/Fall 98 - Beth Sweet [more]
Unread 16-02-2013, 18:30
RUFINESS's Avatar
RUFINESS RUFINESS is offline
FRC #3244 (Granite City Gear Heads)
RUFINESS is an unknown quantity at this point
Exclamation Warning bad vex pro sipke
While temporarily disconnecting our compressor our team pulled the breaker from the spike controlling it and noticed that the compressor was still running.
after taking it apart we noticed that the two pins in the middle of the fuse holder were soldered together.
http://www.granitecitygearheads.com/...2013-Spike.jpg
The spike functioned normally ,but does any one know if the two pins in the top left by d6 were supposed to be soldered together?
Thanks FRC #3244
sorry about the image size i haven't posted much
Last edited by artdutra04 : 17-02-2013 at 04:34. Reason: Replaced huge embedded image with link. Please do not embed images in posts that are over 1000ish pixels wide. Thanks.
Unread 16-02-2013, 22:43
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Warning bad vex pro sipke
If it works after the breaker is pulled, then yes, you pulled enough current at some point to melt the solder and jump the gap. You should be able to fix it with a soldering iron, assuming it functions normally otherwise.
Unread 16-02-2013, 23:29
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
They can't use it on their robot if they fix it
Unread 16-02-2013, 23:36
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
R65
Devices may be repaired, provided the performance and specifications of the component after the repair are identical to those before the repair.
I can verify that the joints between J4 and J3 shouldn't be connected, and that (at least on the one I have infront of me) The two pads at D6 aren't connected, but it looks like they are on the same trace so it shouldn't matter.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 16-02-2013, 23:54
R65
M. Devices may be repaired, provided the performance and specifications of the component after the repair are identical to those before the repair.
Unread 17-02-2013, 02:30
Originally Posted by Mark McLeod View Post
R65
I was unaware that extended to electrical components
Unread 17-02-2013, 09:40
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Its not a bug its a feature!!! Beats arguing that a resettable breaker should be legal there.
Unread 17-02-2013, 10:55
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
It looks like something with a good hand at soldering can fix. We fixed one of the main terminals that came undone for some reason on our spike and it works fantastically. Judging from the picture, there is a lot of solder on that joint, as well so you might want to remove some of that.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
