Go to Post but who knows what you might want to try next? - dlavery [more]
Unread 17-02-2013, 11:36
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Exclamation Photo Switch!
Hello, this is team 2559 and we are trying to set up a photo switch that was used for the line tracker back in 2011. Can anyone help. We are trying to program it in java to activate a pneumatic pump when there the sensor isn't detecting anything. Can you help? We really need to try to get this done since we are out of time and some other teams are coming to our school to practice. Thanks in advanced!
Unread 17-02-2013, 17:52
alexhenning alexhenning is offline
WPILib Developer
FRC #0348
alexhenning will become famous soon enough
Re: Photo Switch!
What issues are you having? Is it wired correctly? Do you have code problems?
A quick search found a few resources that might help:
- http://www.chiefdelphi.com/forums/sh...ad.php?t=89840
- http://www.team2648.com/photoswitches.html
- The Netbeans plugin has the 2011 example code.
Take a look at these and if you have specific questions, post back and I'll try to help.
Unread 17-02-2013, 21:43
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Re: Photo Switch!
It is a programming problem we have. So what we are trying to do is when there is light we want it to activate our solenoid and when it is dark we want it to close our solenoid. Our solenoid isn't spring resettable this year so here is what i have so far.
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.Solenoid;
public class test extends IterativeRobot {
DigitalInput lightsensor = new DigitalInput(2);
Solenoid solenoid5 = new Solenoid(5);
Solenoid solenoid6 = new Solenoid(6);
public void teleopInit() {
solenoid5.set(true)
solenoid6.set(false)
public void teleopPeriodic() {
if(lightsensor.getAnalogTriggerForRouting() == false) {
solenoid5.set(false);
solenoid6.set(true);
}else{
solenoid5.set(true);
solenoid6.set(false);
So part of this code works, When the sensor is tripped it reads dark and solenoid 5 is set false and 6 is set true, but when it sees light again it doesnt reset.
Unread 17-02-2013, 22:49
WPILib Developer
FRC #0348
Re: Photo Switch!
You should replace the line:
with
if(lightsensor.get() == false) {
getAnalogTriggerForRouting() is not what you want to use to get the value of a digital input. The get method returns whether or not it is actually triggered.
Unread 18-02-2013, 09:48
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Re: Photo Switch!
Ok thanks! I will try this later on this afternoon and let you know how it works out.
Unread 18-02-2013, 15:58
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Re: Photo Switch!
This didn't work. Is there a different way?
