Go to Post Yes, good job being calm and asking about the validity of a rumor before fanning the flames and assuming the conspiracy must be true. - Greg McKaskle [more]
Unread 17-02-2013, 12:04
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Couplings
What is the best way to connect a lead screw to a bag motor.
The lead screw is 1/4-20.
Thanks for the help.
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 17-02-2013, 17:14
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Re: Couplings
It should be pretty simple. You'll need an end of the lead screw turned down to a round shaft, and an appropriate shaft coupling to link the output shaft from your gearbox to the round shaft of the screw. Here is the page for shaft couplings on McMaster-Carr. Also, make sure the screw is properly supported along its length, because they don't turn so well when they're bent.
I'd also like to know what sort of reduction you've decided on for your motor, since a 20 TPI lead is really small. Just using the BAG motor's free speed of 14,000 RPM, that gives you 11-2/3" travel per second (way too fast for almost anything). Since I'm assuming this is a high torque application, you will probably be using something like the VersaPlanetary 100:1 gearbox, which puts you down to little more than a tenth of an inch per second (ideally, in reality it could be even worse). Hopefully some ratio in the middle of those gives you enough torque to do what you need without taking forever, but make sure you're always doing the math on these things.
Unread 17-02-2013, 17:57
inkspell4's Avatar
We've made a simple coupling now and plan to test it Tomorrow.
This is not a high torque application so we are doing direct drive at 50% speed.
