Go to Post Ahem......"where are the President's safety glasses???" - Travis Hoffman [more]
Unread 17-02-2013, 12:36
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Encoder default distance per pulse
Does anyone know what it is? Other members of my teams made changes to the finalized code but i was using the default distance per pulse and i need to fix my values
e/ nvm its just 1.0
2e/ another question: whats the proportinal constant for converting an encoder value to degrees? (i want to turn 45 degrees but i need to know what to scale the encoder to)
Unread 17-02-2013, 14:09
BradAMiller BradAMiller is online now
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Encoder default distance per pulse
e/ nvm its just 1.0
The distancePerPulse tells the Encoder object how far the robot travels in a single pulse so you can call the convenience method getDistance() that would return the robot distance traveled. To set the value you need to know the the wheel diameter, the number of encoder counts per revolution, and any transmission ratios that might apply.
Here's the code in WPILib to getDistance():
    public double getDistance() {
        return getRaw() * decodingScaleFactor() * m_distancePerPulse;
You can see it simply takes the raw number of counts and multiplies it by the distance per pulse that you provide.
Do you mean for the robot to turn 45 degrees or are you looking for 45 degrees of shaft rotation?
Brad
Brad Miller
Robotics Resource Center
Unread 17-02-2013, 18:12
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
I meant turn the robot 45 degrees :\
the constant i was looknig for is roughly 1727/90 for a 1 DPP
