Go to Post I can't think of a match where we didnt do the ritual. We always called it... "Deploying the code" - Briansmithtown [more]
Unread 02-17-2013, 01:31 PM
BradAMiller BradAMiller is online now
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Launching a command with a second thumbstick
Originally Posted by nickpaterni View Post
We are using an Xbox controller for robot control, and would like to use the right thumbstick to call a command - specifically to be able to use the value from GetRawAxis() to determine the speed at which we activate a Victor. I know how to get a button to launch a command in OI, but don't know how to make movement of the right thumbstick do the same. Any ideas?
It seems like you want a command that you schedule in teleopInit() that will just grab the joystick value and drive the motor. It can do that independently from everything else in your teleop code.
Brad Miller
Robotics Resource Center
