Go to Post But plywood is so awesome on robots...... But I guess shiny usually always wins out huh? - Jon K. [more]
Unread 17-02-2013, 15:15
Kingston951 Kingston951 is offline
FRC #1943
Kingston951 is an unknown quantity at this point
WindRiver Won't deploy
it's stuck in here
Unread 18-02-2013, 01:35
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Re: WindRiver Won't deploy
We'll need a bit more information to know the trouble. Here's a few things...it appears you are from FRC team 1943. Is this true?
1) open a command prompt windows-R and run the 'cmd' command. At the command prompt, try 'ping 10.19.43.2' when you are connected via ethernet cable to the robot. If you do NOT get replies from the ping, then you have an IP address issue. We can address that as you give some responses...
2) If your ping worked, then your cRio is ok...so the more likely cause is that the "FIRST downloader/deployer" is not configured. In Windriver Workbench, go to Window->Preferences... and click on the FIRST Downloader item. You'll find a 'team number' there. Set it to your team number and then browse to your project directory/PPC603gnu/Debug/... and find the '.out' file down in those directories - this is the file that needs to be downloaded.
Let us know this part and we'll start from there...
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
