Go to Post Glitter… lots of glitter. - Andrew Schreiber [more]
Unread 17-02-2013, 15:27
EyalD EyalD is offline
FRC #1943
EyalD is an unknown quantity at this point
Robot code isn't running after deploy
We had a weird problem: After deployment\debug on a specific computer, the robot code slot in the driver station is green but after Enabling the robot it doesn't do anything (no matter what kind of code it is - Simple or Command based).
Unread 17-02-2013, 16:46
Tanaythan's Avatar
Tanaythan Tanaythan is offline
Programmer
AKA: Tanay Nathan
FRC #3256 (Warriorborgs)
Tanaythan is an unknown quantity at this point
Re: Robot code isn't running after deploy
Open up the NetConsole and check what kind of errors you are getting from there. Sometimes, copying and pasting your code into a new project works (well at least for me).
Tanay Nathan
Programmer
Team #3256 Warriorborgs
Unread 17-02-2013, 18:37
FRC #1943
I don't know if its relevant but in a different computer when we push debug the code works perfectly, just thought it's worth mentioning.
