Go to Post Seriously, when I grow up (or if I grow up) I want to be just like Al. - Paul Copioli [more]
Unread 16-02-2013, 20:22
tmccalister tmccalister is offline
FRC #2985
tmccalister is an unknown quantity at this point
Programming a super shifter/gearbox
How? Programming four motors as the wheel is simple but how do you set the actual super shifter to change between high gear, low gear.
Unread 16-02-2013, 21:34
capnslow capnslow is offline
FRC #3131
capnslow is an unknown quantity at this point
Re: Programming a super shifter/gearbox
If I understand you question it's usually shifted by either a sever (special kit) or pneumatic cylinder (also a special kit). Most team prefer the pneumatic option because it's more rugged and lower shift time.
I'm no expert but no one else has replied. Anything said above could be false.
Unread 16-02-2013, 21:37
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Find out from your electronics/pneumatics people how the solenoids work, and look at the Solenoid class in wpilibj to get started on controlling them. If you need someone to review the code, I'd be happy to take a look.
All opinions are my own.
Unread 17-02-2013, 15:35
FRC #2985
Its just a gear box that has a port that goes into your digital sidecar. it allows it to switch your motors from a larger gear to a smaller gear, kind of like a bicycle.
Unread 17-02-2013, 15:38
FRC #2985
I know how to program it I just need to know how to program this specific gearbox. I can post a picture if you need it.
Unread 17-02-2013, 15:57
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
The simplest method of programming a shifting gearbox is to map one button on the joystick or game pad to control the shifting pneumatic cylinder, and hen do tank or arcade drive as desired.
In this case, the CIM motors are programmed exactly the same as a regular single speed gearbox. Then program your desired trigger button on the joystick to control the solenoid. Drive without the button pressed, and it is in low gear. Press and hold the trigger button, it shifts to high gear.
Art Dutra IV
世上无难事,只怕有心人.
Unread 17-02-2013, 17:21
FRC #2985
That makes a lot of sense. But this isnt a pneumatic so theres no solenoid. its just a small piece that moves up down. and changes from a smaller gear to a higher gear. I understand the theory behind it I just don't know what the class is for the gear box. It plugs in where the jaguars go but I think I would encounter problems if I programmed it as a jaguar. (sorry im a little confused about this because the electronics team doesnt really know how to put this together.)
Unread 17-02-2013, 17:31
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
You are describing a servo. So you would program this as a servo object presuming it is like or is a Hitec HS-322
http://www.trossenrobotics.com/store...bby-servo.aspx
Unread 17-02-2013, 18:59
FRC #2985
Thank you so much sir. You are a gentleman and a scholar so...
Servo supershifter = new servo (1); ?
Then how would I set it to change between gears?
Unread 17-02-2013, 21:17
MagiChau's Avatar
AKA: Michael Chau
I myself use the set() method so here's some java pseudo code for controlling it with joystick buttons. This assumes you want the servo to go through the full range of motion from 0 to 1. There is also a setAngle() method you could use.
if (buttonIsPressed()) {
    servo.set(1);
} else if (anotherButtonIsPressed()) {
    servo.set(0);
Unread 18-02-2013, 18:39
FRC #2985
I figured it was that so I had put it in and it told me it was wrong. then I realized i forgot to capitalize servo. -_- gotta love programming.
