Go to Post By seeing other robot designs, teams can plan before hand on how to defend or defeat it. - Don Wright [more]
Unread 17-02-2013, 16:46
ww2freak8 ww2freak8 is offline
FRC #4345
ww2freak8 is an unknown quantity at this point
Exclamation Programming a compressor
Pleas Help! we are having trouble programming and getting the compressor to work, we have it wired correctly via the port 1 and 1 on the DIO and Relay ports and the compressor does have the pressure sensor hooked up but have not the slightest clue on how i would get it to start running, anything would be of help, preferebly pictures too. thanks!
Unread 17-02-2013, 16:52
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: Programming a compressor
Part of a general LabVIEW document I wrote explains how to initialize and configure a compressor. You can read what I wrote here.
Unread 17-02-2013, 17:00
FRC #4345
it says i cant access that link because it requires a hightend security
Unread 17-02-2013, 17:02
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
I was able to access it fine, but I've attached it as a PDF for you.
Unread 17-02-2013, 17:09
FRC #4345
Thanks! ill be checking this out right now and post any results i get shortly
Unread 17-02-2013, 17:49
FRC #4345
yeah it still isnt working, ill provide screenshots and maybe ya guys can tell me whats wrong?
Unread 17-02-2013, 17:58
bvisness's Avatar
Did you make sure to put the control loop in Periodic Tasks? You'll need that if you actually want the compressor to do anything.
Unread 17-02-2013, 18:01
FRC #4345
yeah its at the bottom here.
Unread 17-02-2013, 18:05
bvisness's Avatar
Your code looks fine. I do notice that your code has Relay 3 listed for the compressor in Begin, but you said in your original post that you have the compressor connected to port 1 on the relay module. That might be your problem...
Unread 17-02-2013, 18:06
FRC #4345
oh yes, i noticed that. that wasw because i was testing something eright before i posted that, but that isnt the problem
Unread 17-02-2013, 18:10
FRC #4345
wish i knew why it wont work =(
Unread 17-02-2013, 18:13
plnyyanks's Avatar
AKA: Phil Lopreiato
Are you sure everything is wired correctly? Can you take a multimeter and see if the spike is sending voltage to the compressor? What colour is the LED on the spike? What is the pressure switch saying (can also be checked with a multimeter)?
Unread 17-02-2013, 18:21
FRC #4345
it looks like we are getting up to 7 volts off the spike relay, and the little light on it is orange, didnt know the pressure switch says anything
Unread 17-02-2013, 18:39
FRC #4345
also it connected to a spike relay but idk if thats what causing the issue.. just know its still not working
Unread 17-02-2013, 19:26
plnyyanks's Avatar
AKA: Phil Lopreiato
That doesn't sound right. You should be getting +12, -12, or 0. Check the input wiring - it should go a terminal on the PDB protected by a 20 amp breaker.
If it's solid orange, that means it's outputting neutral (zero volts). If it's trying to get your compressor to run, it'll turn green (forward). There should be a PWM wire between the spike and Relay port 3 on your digital sidecar (like you specified in code)
When the pressure going through the pressure switch is <120 psi, there will be an open circuit between the two wires coming off it (which should go to DIO 14, like you specified in code). That circuit will close when the pressure reaches 120 psi. This tells the cRIO to turn off the compressor.
Take a look at the Signal Wiring Diagram and the Power Wiring Diagram to see how to wire the pressure switch and a spike relay.
