Go to Post So yeah, everyone please remember that lathes are one of the most dangerous machine tools you'll encounter. And keep your hand on the chuck key whenever it's in the chuck. If you never let it go till it's out of the chuck, it's stupendously less likely to take flight. - Kevin Sevcik [more]
Unread 17-02-2013, 15:27
EyalD EyalD is offline
FRC #1943
EyalD is an unknown quantity at this point
Robot code isn't running after deploy
We had a weird problem: After deployment\debug on a specific computer, the robot code slot in the driver station is green but after Enabling the robot it doesn't do anything (no matter what kind of code it is - Simple or Command based).
Unread 17-02-2013, 16:46
Tanaythan's Avatar
Tanaythan Tanaythan is offline
Programmer
AKA: Tanay Nathan
FRC #3256 (Warriorborgs)
Tanaythan is an unknown quantity at this point
Re: Robot code isn't running after deploy
Open up the NetConsole and check what kind of errors you are getting from there. Sometimes, copying and pasting your code into a new project works (well at least for me).
Tanay Nathan
Programmer
Team #3256 Warriorborgs
Unread 17-02-2013, 18:37
FRC #1943
I don't know if its relevant but in a different computer when we push debug the code works perfectly, just thought it's worth mentioning.
