Go to Post Yes, good job being calm and asking about the validity of a rumor before fanning the flames and assuming the conspiracy must be true. - Greg McKaskle [more]
Unread 17-02-2013, 18:47
Re: How to Compile Labview code to an .exe
The c is a folder or directory and in it is the ni-rt, then startup, and in that startup.rtexe.
Does the Build succeed? If so, you should be able to Run as Startup which will cause the cRIO to reboot, and the DS should show the code running. The boot time is somewhere between 20 and 30 seconds.
Greg McKaskle
