Go to Post Im ready for Christmas, then second Christmas!!!! - Raumiester2010 [more]
Unread 17-02-2013, 18:51
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
VEX BAG and/or mini-CIM 217-3351 mounting
how do you mount this motor onto a piece of metal and attach a wheel to it.
Unread 17-02-2013, 19:30
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: VEX BAG and/or mini-CIM 217-3351 mounting
For the BAG motor Generally you would put a gear box on it like this one.
http://www.vexrobotics.com/vexpro/ge...planetary.html
Unread 17-02-2013, 20:17
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
I am assuming to want to mount them on their face. If so, print the attached PDF document on a laser printer full size, use double sided tape to tape it to your piece of metal where you want the motor mounted, then drill the holes to the noted sizes after center punching them. These are for direct driving the motors. If you use the Versa Planetary gearbox for the BAG motor, follow the Mini-CIM holes.
If you want to mount the motor from the side, use a hose clamp or two from the auto parts store.
-T
