Go to Post Don't Canadians spell it that way? Someone should cheque on that.... - Travis Hoffman [more]
Unread 16-02-2013, 21:26
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
pic: Our Big Drill Press
Unread 16-02-2013, 21:33
seannoseworthy's Avatar
seannoseworthy seannoseworthy is offline
seannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to behold
Send a message via MSN to seannoseworthy
Re: pic: Our Big Drill Press
More specifically called a Radial Arm Drill
Unread 16-02-2013, 22:25
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
Or the more technical term, Overkill.
J Wallace IV
Truck Town Thunder
Just a college student now.
Unread 16-02-2013, 22:33
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
When you have time, figure out the kWHr per hole. Kinda like the gallons/mile computations for ocean liners.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 16-02-2013, 23:17
Bochek's Avatar
AKA: Adam Bochek
I prefer the term adequate
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 17-02-2013, 17:33
Bochek's Avatar
AKA: Adam Bochek
Lets assume it takes 30 seconds to drill the average hole, and that we use the machine to 25% of its available power.
The motor is rated at 600V 15A
That's 9kw
25% of 9kw is 2.25kw
30 seconds is approximately 0.00833 of an hour.
2.25kw * 0.00833 = 0.0187425 kWHr per hole or ~18.75 watt hours per hole.
by that math 3 holes uses the same amount of power as it takes to run an 60w lightbulb for a hour.
- Adam
Unread 17-02-2013, 21:07
FRC #2170
Talking Re: pic: Our Big Drill Press
You should change that 60w bulb to a FIRST e-watt LED.
