Go to Post What else could you do with a t-shirt? Wait... never mind... I retract my previous statement and realized this is FIRST and we can do anything with anything. ;) - Jeremiah Johnson [more]
Unread 17-02-2013, 21:13
y-aji y-aji is offline
FRC #3734
y-aji is an unknown quantity at this point
cRIO blink codes?
We're suddenly getting a blink code on the lights of "Long Long Short Short" repeatedly. Is there a chart for blink codes?
Unread 17-02-2013, 21:45
Re: cRIO blink codes?
Look in
cRIO FRC II: CompactRIO cRIO-9075/9076 Operating Instructions and Specifications
cRIO FRC I: CompactRIO cRIO-9072/3/4 Operating Instructions and Specifications
Number of Flashes Every Few Seconds Indication
  • 1 = The chassis is unconfigured.
  • 2 = The chassis has detected an error in its software. This usually occurs when an attempt to upgrade the software is interrupted. Reinstall software on the chassis.
  • 3 = The chassis is in safe mode, or there is no software installed on the chassis.
  • 4 = The software has crashed twice without rebooting or cycling power between crashes. This usually occurs when the chassis runs out of memory.
  • Continuously flashing = the chassis has detected an unrecoverable error.
  • Continuously flashing or solid = the device may be configured for DHCP but unable to get an IP address because we use static addresses in FRC.
Unread 17-02-2013, 22:09
FRC #3734
Thank you, sir. I'll take a look at that in the morning.
