Go to Post I like drifting, but I have to go WRC. Putting a car where it doesn't belong feels right, like combining together drill motors and power window motors and putting them on a big patch of carpet. - Billfred [more]
Unread 17-02-2013, 21:13
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Extending above 60"
I'm really looking forward to seeing a bit of a rock-paper-scissors game play out this year. It seems to me that a full court shooter sitting in its loading zone that can drain their alliance's frisbee supply into the top goal is going to dominate this game most of the time in qualifiers. But in elimination matches, they're going to get shut down if an opposing robot has the ability to extend their robot high enough to block those shots. If there's enough defense out there, then climbing looks good by comparison since it's hard to defend against.
So my question is, are there robots out there that have this capability to extend upwards for defensive purposes? It's a risk to build something like that, but I think those robots are going to get snapped up in alliance selections this year.
Unread 17-02-2013, 21:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Extending above 60"
Seems to me (and you, apparently) that those robots will be doing the picking.
Unread 17-02-2013, 21:37
tinybob20 tinybob20 is offline
AKA: Jeremy
FRC #1559 (DevilTech)
tinybob20 is an unknown quantity at this point
Speaking from a team with (potentially) a full court shooter, I can see these types of defense bots being quite annoying. We could easily get shut down by a bot just sitting in-front of us, with a shield raised. But I could also see us potentially breaking a robot, just from our Frisbee speed/impact force.
Unread 17-02-2013, 21:58
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
How strong is your shooter looking right now? Also, it is nice to throw them hard, but are you accurate at all?
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 18-02-2013, 18:00
AKA: Jeremy
Currently, we don't have a good bearing on how accurate our shooter is, but it does seem to hit a foot to half a foot radius circle at 50ft. As for how powerful it is, we can put a pretty nice dent in drywall at 20ft.
Unread 18-02-2013, 21:58
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
It is incredibly hard to break a robot. I'd guess that a 1/32nd polycarb shield, swiss cheesed, and attached to thin angle, could hold against a 100mph frisbee shot no problem.
Unread 17-02-2013, 22:18
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
With a full court shooter, a tall robot would put a damper to our strategy. If a tall robot does get in our way, we could easily move to the pyramid hot spot. It would just take more time.
Same with us. Our shooter caused my hands to sting when catching discs from over 75 feet away.
Our shooter is about 50% from the feeder station into the high goal (upwards of 75% when shooting into the middle). We are also about 75% into the top goal when shooting into the high goal from the pyramid sweet spot.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 18-02-2013, 03:29
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
A deflector can have a pretty good slope to it. It doesn't have to completely block the frisbee.
Unread 18-02-2013, 03:38
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We can get up high. Our most recent blog post has pictures of our robot and practice/prototype robot fully extended.
http://3847.blogspot.com/
We had the idea of blocking full court shooters pretty early on. The horns at the top of the lift get to 83.75".
The robot is as stable as the robot I worked on in 2011 for Logomotion. It would tip if we accelerated full throttle (6 CIMS) at full height but not if a we were just pushed in the bumper zone. We also have bumpers plus 20 more pounds of weight to add to the frame.
Unread 18-02-2013, 08:56
1629GaCo's Avatar
1629GaCo 1629GaCo is offline
FRC #1629 (GaCo)
1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute1629GaCo has a reputation beyond repute
1629 GaCo has the ability to extend to 84" to block shots.
Engineering Inspiration
2008,2009,2010,2011, 2011 Championship,
2012 Championship,2013, NOVA District Event 2016, CHS District Championship 2016
Chairmans Award
2010, 2012, 2014, 2015, NOVA District Event 2016
Regional Champions
2006, 2014, 2015, 2016
Unread 18-02-2013, 09:01
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
We've noticed that many (most?) bots have their shooters pretty low. Our bot does not extend but it is 60" high and we think we will be able to interfere with a number of shooters.
Unread 18-02-2013, 17:55
Andrei1559 Andrei1559 is offline
FRC #1559
Andrei1559 is an unknown quantity at this point
Our shooter is SOOO much better than yours. We can climb three levels faster than you ever could. In fact I regret working with you. Love you Jeremy!
Unread 18-02-2013, 22:16
Andrew Lawrence
Posts: n/a
A risk? How is making a simple deflector that goes up and down a risk? In my opinion, an effective deflector can rise up, shut down a single shooter, and be on its merry way. No risk. No challenge. Maybe an hour's worth of work on your robot. It's no risk, and can make allow your robot to shut down the offensive strength (and possibly game piece feeding) of an entire alliance.
Unread 26-02-2013, 01:14
TeraViks's Avatar
TeraViks TeraViks is offline
AKA: Brian Induni
FRC #3145 (TeraViks)
TeraViks is a jewel in the roughTeraViks is a jewel in the roughTeraViks is a jewel in the roughTeraViks is a jewel in the rough
Break the robot? We did the ultimate test, not on purpose mind you. I'm trying to get my marketing team to let me post the video of our bot climbing to level 3, dumping the colored disks, then falling from above the top of pyrimid. The next video shows the bot being righted and going off to shoot more disks! We drank our own Koolaid and followed the Robot Delivery Life Cycle.
Brian
FIRST team 3145 (notice I'm doing Dean's homework!)
The TeraViks
Coeur d'Alene, Idaho
Unread 26-02-2013, 01:39
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
We thought this from the beginning.
We went with a shooter/climber combo that would let us
1) Shoot cross court
2) Climb 30 pts
and
3) Play defense.
The climber extends to the max height in order to block shots.
Couple this with our mecanum drive, and its hard for anyone to get around our D.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
