Go to Post I wonder if Dave thinks the Chief Delphi kids are pimp... - Mike Ciance [more]
Unread 17-02-2013, 20:00
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Rules on building after bag day?
You're supposed to treat the robot as if it's in a crate in a drayage facility like the old days of shipping. Obviously, you can't measure/inspect/interact with it if it's in a drayage facility.
Unread 17-02-2013, 20:16
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
That's the trouble with tradition. Only we older fogies remember it. Talk of drayage facilities and crates only confuses the newer guys. In the absence of specific instruction to not even look at the bagged robot, what should a fresh mind think of that? If FIRST wanted such stringent measures, they're capable of writing the rules to fit their desires. An opaque bag would go a long way to reinforce the behaviors being espoused here.
BTW our little, inside "guy" has a pillow and an iPad.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 17-02-2013, 20:26
Originally Posted by DELurker View Post
Lacking an official definition of "hands-off", I would actually interpret this as meaning that the robot cannot be modified, adjusted, or tweaked while it is in the bag. Measuring would not violate that. Turning wrenches, drilling holes, and wiring components would violate that.
You should note R-18E, which stipulates that you can work on your withholding allowance without interfacing with the robot. I would interpret making a measurement as interfacing with the robot, particularly if the tape measure were in the bag. However, if you were to make measurements on parts you were planning to need measurements on before the robot went into the bag, note the measurements, and use the notes, you'd be just fine. Or if you built a jig to simulate that part of the robot, you'd probably be OK.
Unread 17-02-2013, 21:44
DarthCoder DarthCoder is offline
FRC #4309
DarthCoder is an unknown quantity at this point
So could we leave the cRIO and motor controllers and other electronics stuff out of the bag and work on image processing and programming?
Unread 17-02-2013, 21:58
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
It depends on how you're doing on your withholding allowance. If you leave all of your wires hooked up, it's no longer in its COTS state, it has been modified to fit the function of your robot, if only slightly. You can still bring that sort of thing in, just make sure it (plus any other parts you bring) is under the 30 pound limit. The other option is taking it apart and wiring it up at competition, which could take away time from other things, like getting the rest of your robot ready and going to practice matches. There aren't restrictions against coding during this period, so do as much of that as you want.
Unread 17-02-2013, 22:18
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
I fully agree that the presumed intent is that there's an invisible fence around the robot. However, I think the GDC recognizes that it is honor-system. I also thought their choice of "interfacing" was interesting. Interfacing to me means putting parts into slots, accessing electronics, etc.
Overall, this section could use some clarity of intent for those of us who are post-drayage. Failing that, they should ship out black plastic bags rather than clear and force everyone to put 30 lbs of packing peanuts in it on top of the robot. Maybe packing peanuts could be the scoring pieces for 2015's game? A robot version of Tricky Tricky Trash Truck? (Who gets the reference?)
Yes, I understand that it's straying into rules-lawyering. No, we don't interact with the robot in any way once it is bagged (other than moving it out of the way because it is inevitably in the wrong spot for the night's planned activities). However, I'm not sure what you can do to prevent teams from interacting with the robot under the current system.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 18-02-2013, 00:23
Negative 9 Negative 9 is offline
FRC #0611
Negative 9 is an unknown quantity at this point
Do bumpers count as part of the 30 lb limit?
Unread 18-02-2013, 08:08
AKA: William Lydick
no team (n/a)
No.
R21
Teams may bring a maximum of 30 lbs of FABRICATED ITEMS to each event to be used to repair and/or upgrade their ROBOT.
For Teams attending 2-Day Events, these FABRICATED ITEMS may be used during the Robot Access Period and/or brought to the Event, but the total weight may not exceed 30 lbs. FABRICATED ITEMS constructed during the Robot Access Period and bagged with the ROBOT are exempt from this limit.
The OPERATOR CONSOLE, BUMPERS, and any ROBOT battery assemblies (as described in R05-A) are exempt from this limit.
With 1370 --
Unread 18-02-2013, 13:40
toastnbacon toastnbacon is offline
AKA: James
FRC #3169 (Saintborgs)
toastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the rough
If you're only working on programming, I would consider only leaving out the cRio and maybe the camera. You can build a new electronics board that won't go on the robot, therefore it wouldn't count towards your 30 lbs. The cRio and camera should be COTS. The only thing I wouldn't be sure about is the camera power cord, if it's cut. But at competition, you can put the cRio and camera back on and still have most of your 30 lbs to spare!
"This must be what going insane feels like."-Simon Tam, Firefly
Unread 19-02-2013, 14:00
President 1502 President 1502 is offline
FRC #1502
President 1502 is an unknown quantity at this point
How does having a tape measure in the bag help unless you rip the bag to use it?
Unread 19-02-2013, 14:59
The bag is flexible. They're manipulating the measuring tool through the bag, which is probably too literal an interpretation of "hands off" for most of us.
