Go to Post You can't expect a situation to get better if you don't make an attempt to confront it. - AndyB [more]
  #61   Spotlight this post!
Unread 17-02-2013, 22:42
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
Re: Pre-Stop Build Scrimmages - What Have We Learned So Far?
Were they angle shots?
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
  #62   Spotlight this post!
Unread 17-02-2013, 22:52
GBilletdeaux930's Avatar
GBilletdeaux930 GBilletdeaux930 is offline
AKA: Greg
FRC #0930 (Mukwonago Bears)
GBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to all
Originally Posted by Mike Norton View Post
Any team get the color ones on top for the 5 points?
Yeah we managed to get one up there from shooting from the ground one match, and our human player another match.
  #63   Spotlight this post!
Unread 17-02-2013, 23:02
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Originally Posted by DELurker View Post
Can you give a little more detail on that? It sounds like a good learning moment ... and probably a really entertaining video or photo set...
First of all, excuse my typo of axle, which I can't edit now.
We are running a 6-wheel drive with a 1/8 drop on the centre wheel, with AM performance wheels geared quite aggressively for 15 and 7 ft/second (calculated including efficiency loss). Performance wheels are threaded for 10-32. Each wheel had 3 grade 8 10-32 bolts in them.
About 10 minutes into driving yesterday, we noticed VERY limp chain. Upon closer examination, we found that the entire sprocket assembly had sheared off of the middle wheel. All 3 bolts had sheared. We promptly replaced the wheel with the bolts ends lodged in with our spare, pulled all the wheels off, and added 3 more bolts to each wheel.
Today I drove just as aggressivly, and we haven't had any issues (at least not with the drivetrain ). I suspect they sheared when I was braking while downshifting, but I'm not sure.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
  #64   Spotlight this post!
Unread 17-02-2013, 23:32
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Originally Posted by cmrnpizzo14 View Post
Today at the Rally I saw X-Cats (191) having a ton of trouble with disks hitting the chains and bouncing out.
The goals were pretty tight so many bounced back all day long. When the shots got through whatever unfortunate team was in the middle got frisbees rained down on them as this video shows.
  #65   Spotlight this post!
Unread 18-02-2013, 00:31
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
I didn't see this earlier in the thread I think. Drive teams are going to have to become desensitized to frisbees slamming into their window a couple feet from their face from human players in the last 30 seconds, at least at events where a majority of the frisbees aren't ending up being used by robots.
  #66   Spotlight this post!
Unread 18-02-2013, 11:00
dsmoker's Avatar
dsmoker dsmoker is offline
Robo Mom
dsmoker has much to be proud ofdsmoker has much to be proud ofdsmoker has much to be proud ofdsmoker has much to be proud ofdsmoker has much to be proud ofdsmoker has much to be proud ofdsmoker has much to be proud ofdsmoker has much to be proud ofdsmoker has much to be proud of
Originally Posted by Bill_B View Post
558 had success with the pyramid goal. Their tall shooter would lob nearly vertically. When I saw it first shooting under the 2 and 3 goals, I wondered what they were trying. Strangely they only shot three at a time. Their first try I saw for the pyramid was three non-scoring white disks. It drew cheers from the crowd. Other tries with colored disks had varying success.
One of our primary goals at Suffield was to perfect our shooting angles for the 2, 3 and tower goals. That's what we were tweaking most of the day. We were pretty pleased with what we were able accomplish and have more up our sleeve for WPI and CT.
Denise Smoker, Mentor, Team #558, Elm City RoboSquad
Finalist, N.E. District Championshp 2014 (thanks 195 and 5122)
Judge's Award, N.E. District Championship 2014
Winner, Hartford District Event 2014 (thanks 177 and 5129)
Chairman's Award, Southington District Event 2014
Winners, Southington District Event 2014 (thanks 195 and 999)
Creativity Award, WPI Regional 2013
Finalist, CT Regional 2012 (thanks 1071 and 2067)
Engineering Inspiration Award, CT Regional 2010
Judge's Award, CT Regional 2009
Johnson & Johnson Gracious Professionalism Award, CT Regional 2008
Woodie Flowers Award (mentor Ernie Smoker), CT Regional 2008
Winner, CT Regional 2007 (thanks 195 & 1124)
Daimler-Chrysler Team Spirit Award, CT Regional 2007
Finalist, CT Regional 2006 (thanks 181 & 356)
Imagery Award, CT Regional 2005
  #67   Spotlight this post!
Unread 18-02-2013, 11:13
neshera's Avatar
neshera neshera is offline
Nesher G. Asner
AKA: Nesher G. Asner
FRC #1625 (Winnovation)
Team Role: Parent
neshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud of
Koko Ed - thanks for the video! Good driving on the part of your team.
One note: Your human players will not be able to feed the discs into your robot exactly as they did on the video. The feeder slots on a real field are not simple slots in the plexiglass; they have a covered chute on the driver's side of the of the feeder stations. So you won't be able to hold on to a disc as it passes through the slot.
Good luck!
Do not panic! All is well!
- Kevin Bacon in Animal House
  #68   Spotlight this post!
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
There were some matches where there were more penalty points than scores by team skill and there were very low scoring matches where nothing much happened at all.
What penalties were committed the most? What do you think the reason of these bad matches was?
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
  #69   Spotlight this post!
Unread 18-02-2013, 11:25
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
there was a pretty small field and it seemed many robots were not complete (176's robot stood out. A former world champion and winner of several Blue Banners does not build a coffee table on wheels. they are probably still finishing up the competition bot) and thus did not score very well at all.
The match that stuck out to me was a qualification match where the blue alliance raced out to a 20 to nothing lead but lost the match 40 to 30 due to a pair of technical fouls incurred by the feeder by reaching their hands through the slot. There were a couple of other matches where there were more penalty points than points scored as well.
  #70   Spotlight this post!
Unread 18-02-2013, 11:26
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Good luck!
Our practice field has the feeder station with the chutes on the slots so Hawa can get practice dropping the Frisbees into the robot properly.
  #71   Spotlight this post!
Unread 18-02-2013, 12:41
neshera's Avatar
Nesher G. Asner
Team Role: Parent
Excellent.
  #72   Spotlight this post!
Unread 20-02-2013, 02:37
ENIAC's Avatar
ENIAC ENIAC is offline
AKA: Matthew Petersen
FRC #5958 (Blue Wave Robotics)
ENIAC is a jewel in the roughENIAC is a jewel in the roughENIAC is a jewel in the roughENIAC is a jewel in the rough
Originally Posted by Garten Haeska View Post
We learned that our pick up system was very effective and will be very nice in autonomous.
Our shooter works very well shooting into the 3pt goal with chains from the feeder station and from the front and back sides of the pyramid.
Last our 10pt climber worked like a charm and was one of the fastest and easies hanging mechanisms at our event. 3 seconds and only 25psi.
We also learned that if a frisbee is upside down and gets stuck on your wheel,it can really mess with your driving until it gets dislodged.
What kind of pickup did you use?
  #73   Spotlight this post!
Unread 20-02-2013, 02:46
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
One thing @ Rally that stuck out was some teams sported some serious cannon that fired Frisbees at a shocking rate of speed. While FIRST has cracked down on Human Players unleashing an insane hail of Frisbees I actually wonder how soon is it FIRST issues a speed limit for firing Frisbees like they did with the robots back in 2006.
  #74   Spotlight this post!
Unread 20-02-2013, 09:32
EricLeifermann's Avatar
EricLeifermann EricLeifermann is online now
That was a short break
FRC #2826 (Wave Robotics)
I sure hope they don't....
2012-2016 Wave Robotics Team 2826
  #75   Spotlight this post!
Unread 20-02-2013, 09:37
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is online now
Robotics Engineer
FRC #0319 (Big Bad Bob)
I don't think FIRST will issue a speed limit like they did in 2006. 2006 was the first competition with projectiles and I think the speed limit they enforced that year was more of a precaution than anything.
Unfortunately, I don't think there is a velocity that the frisbees can be effectively launched at that is also safe for human impact. That being said, if a robot at competition repeatedly shoots frisbees out of the field in an unsafe manner, I assume the refs will issue a warning followed by a yellow card for additional aggregious infractions.
