Go to Post We are here to support each other. - Mike Martus [more]
Unread 17-02-2013, 17:47
Nyle's Avatar
Nyle Nyle is offline
FRC #0422 (The Mech Tech Dragons)
Nyle is just really niceNyle is just really niceNyle is just really niceNyle is just really nice
How to code limit switch to stop movement
Our robot's articulator for adjusting the vertical angle of the shooter has limit switches on the top and bottom to stop it from going too far in either direction. Currently our code has three methods in the shooter articulator subsystem used for moving it: moveUp(), moveDown(), and stop(). The moveUp() and moveDown() methods check if the limit switch they would be moving towards is pressed, if it is not sets the talon to 1.0 or -1.0, and if it is calls the stop() method, which sets the talon to 0. This makes sure that the articulator doesn't extend beyond where it is supposed to travel as long as one of the movement methods is being called continually (currently they are), but if they aren't being continually called the limit switches won't stop the articulator from moving (for instance, if moveUp() were to be called once, it would check the top limit switch, and if it isn't pressed, set the talon to 1.0. This unfortunately won't stop when the limit switch is pressed.). I have a feeling that there is a better way to do this, but I don't know what it is. Any suggestions?
Unread 17-02-2013, 18:39
Re: How to code limit switch to stop movement
This is one application where the Jag has an advantage. You can wire the limit switches directly to the Jag and it handles everything for you.
Unread 17-02-2013, 19:22
Nyle's Avatar
Thanks, I'll keep that in mind for the future, it seems very useful, but we are looking for a software solution at the moment as we don't have the time or space to change to a Jag at this point.
Unread 17-02-2013, 23:09
I have an idea for a small architectural change to make it work. Instead of setting the articulator's motor value directly, have your move() and stop() methods set a global variable. Then have a small piece of "main loop" code that continually reads the global and the limit switches then sets the motor appropriately.
Unread 18-02-2013, 01:13
VCEmblem VCEmblem is offline
FRC #3880
VCEmblem is an unknown quantity at this point
Smile Re: How to code limit switch to stop movement
You should post your code; this is what my team is using at the moment:
if(driveStick.GetRawButton(5) && topLimit.Get() == 1) //The arm will only move up if the limit switch is NOT pressed
         leftArm.Set(-1.0); //Moves the arm up
         rightArm.Set(-1.0);
else if(driveStick.GetRawButton(7) && bottomLimit.Get() == 1) //ditto ^
         leftArm.Set(0.5); //Moves the arm down
         rightArm.Set(0.5);
else
         leftArm.Set(0.0); //Stops moving the arm
         rightArm.Set(0.0);
The way we wired our limit switch makes it so then when the limit switch is pressed, it is equal to "0" and when it is not pressed, it is equal to "1"
Unread 19-02-2013, 18:55
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Generally we wire our limit switches to read 1 when they are pressed (the limit is hit) and 0 otherwise. That way if the switch gets disconnected it reads as though it's pushed, and the mechanism won't move toward the limit. Your team has to decide whether you want the mechanism to still work with a disconnected switch (risking damage) or stop if the switch is disconnected, rendering the mechanism not fully operational. This kind of design consideration is called "risk management."
Digital Inputs are "pulled up" through a resistor to +5v and will read 1 when there's no connection. The pneumatic pressure switch is wired in this manner, a disconnected switch reads the same as at full pressure. Therefore, the pump won't run with a disconnected pressure switch.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 20-02-2013, 17:44
Anyun Anyun is offline
Co-Captain Team 1308
FRC #1308 (Wildcats)
Anyun is an unknown quantity at this point
We're actually doing something similar. Our launcher is lifted using two motors (LifterA and Lifter B), and we wired our limit switches so that the upper is 1 when depressed and the lower is 1 when open. The upper limit becomes open onces the ramp reaches the furthest up we want it to go, while the lower limit becomes closed when it goes the furthest down we want it to go. Our code looks something like this:
if(stick.GetRawButton(4) && UpperLimit.Get() == 1)
// if button 4 is pressed and upper limit is pressed, lifter goes up
LifterA.Set(0.4);
LifterB.Set(0.4);
else if(stick.GetRawButton(5) && LowerLimit.Get() == 1)
// if button 5 is pressed and lower limit is not pressed, lifter goes down
LifterA.Set(-0.4);
LifterB.Set(-0.4);
else
LifterA.Set(0.0);
LifterB.Set(0.0);
