Go to Post Let the team grow, let them fail, let them learn and always be ready to lend a helping hand. I think that's the best way to help rookie teams. - Justin Montois [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 17-02-2013, 13:12
mattachew12 mattachew12 is offline
FRC #3597
mattachew12 is an unknown quantity at this point
error in speed control mode
I'm using two CANJaguars, but only testing on one for the moment, and when I try to set it to the speed control mode, it doesn't give speeds anywhere near what I want, and usually throws an error too
>>>>ERROR: status == -1073807298 (0xBFFF003E) in Read() in C:/WindRiver/workspace/BlackJagBridgePlugin/SerialPort.cpp at line 216
I'm using java and have a quadrature encoder attached to a gearbox, which I believe is causing the odd values, but I don't know why the error is being thrown. Sometimes it works, other times it doesn't. It seems to have something to do with my PID values (20.0, .1, .01) , but I'm not sure. Any ideas?
Error 404-Signature Not Found
Unread 17-02-2013, 23:51
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
Re: error in speed control mode
Your PID values are way too high. Start with a P of 1 or even 0.1. Set the I to something between 0.1 and 0.01. Set your D value to 0.
A good way of playing "what if?" is using the BDC-Comm program to try different gain values. Apply a light load to output to see if the values are adequate, and use the best values you find in your code.
