Go to Post When it all comes down to it, it's not gonna be the medal around your neck that makes the difference, but the memories that you think about when you look back on how you got there that makes the difference. - Beth Sweet [more]
Unread 17-02-2013, 14:47
jake517 jake517 is offline
FRC #4294
jake517 is an unknown quantity at this point
CIMs and Driving
Hello all,
My team is currently having weight issues, and I was wondering if we should take off a couple of our CIMs. Currently, we plan on climbing the ladder for thirty points, and then plan on dumping frisbees for twenty additional points. We also plan on playing defense. Sadly, we are currently a little overweight -- and we have yet to add our dump box.
Is it to our advantage to keep a total of four CIMs driving our tank drive robot, or would it be okay to take off two CIMs and still play defense with only two?
Thanks,
~4294
Unread 17-02-2013, 15:11
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: CIMs and Driving
I am not sure how much it would help but could you use mini Cims?
Unread 17-02-2013, 15:14
FRC #4294
We could, but we are trying to eliminate a lot of weight fast. If having four CIMs for our drive train alone is not worth it, then we definitely need to know.
If the CIMs are worth using (especially for our defensive game) then my team needs to start being creative with losing weight.
Unread 17-02-2013, 15:24
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally Posted by jake517 View Post
Hello all,
Thanks,
~4294
2 CIM's is a really really bad idea. You will probably not be able to turn and will likely trip breakers.
2001-2004: Team 100
2006-Present: Team 254
Unread 17-02-2013, 19:05
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
To know for sure, we'd have to see and evaluate your specific drive setup. It's been done, but will definitely put you at a disadvantage.
Unread 17-02-2013, 19:22
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
How much weight are you looking to loose?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 17-02-2013, 20:42
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
If you are careful I think that you could get by with just 2 CIM's. If you think about it in terms of points, you will probably score those 20 points with the dumper. However, will you be able to effectively prevent the opposing alliance from scoring 20 points? I think that it would be worth it to use only 2 CIM's for driving if you can. It is worth testing and trying but will only 2 CIM's really cut enough weight for you? How much over are you?
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 18-02-2013, 00:16
Shane 2429 Shane 2429 is offline
FRC #2429
Shane 2429 is infamous around these partsShane 2429 is infamous around these parts
if its only a couple pounds grab a drill and cheese hole or drill holes into lexan out where not structural
personally i wouldn't take off those cims if you are playing defense considering you would be dropping you torque in half and would leave that as a last resort
can you please post a picture so we can see your design and see where you might cut weight out
Unread 18-02-2013, 01:00
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
A couple of questions here are:
- How well does your 30 pt climber work? This should be your top priority to make work as it is "guaranteed pts"
- If it does work well, then how sure are you you can make a 20 pt dumper? These mechanisms seem easy at first but I've seen lots of precision engineering go into many of them to be effective
- Do you think you can deny an opponent's alliance 20 pts by playing defense?
Then you can choose between playing defense or a dedicated climb and dumper. The goals don't seem terribly complimentary - a dumper would want to be light and a defender heavyweight.
In all cases, you should try cutting weight elsewhere. Can we see a picture of your robot so we can offer advice?
Unread 18-02-2013, 01:12
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
This may apply less if you have a wide wheelbase, or a drop center.
In general though, if you're already near the weight limit you may have a lot of trouble maneuvering with only 2 CIMs
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 18-02-2013, 11:25
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
never sacrifice your drivetrain. you cut your robots performance in 1/2 for 6lbs. you can shave 6lbs in other places without sacrificing your robots performance.
My Instructables
Unread 18-02-2013, 11:32
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
drive train power is the last thing you want to take off when the robot is overweight. try drilling wholes in your robot, cutting the ends of screws, and changing anything that is steel to aluminum/polycarb. If you are only 5-10 pounds over weight this should do it. (you need 4 cims on the drive).
2014 Colorado Regional Winners (Thanks 3310 and 2543)
2013 San Diego Regional Winners (Thanks 987 and 254)
2013 San Deigo Regional Entrepreneurship Award
2012 Los Angeles Regional Semifinalists (Thanks 599, 3309)
2012 San Diego Regional Finalists (Thanks 399, 2339)
2011 Los Angeles Regional Chairman's Award
2011 BAE Regional Judges Award
Unread 18-02-2013, 11:36
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Driving around should always be your #1 priority. Do not go down to two motors on your drivetrain.
Try robot weight watchers instead
Seriously, give that a look ^
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 18-02-2013, 15:44
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
How many punds do you have to loose?
