Go to Post I told people that I was a summit for world leaders for our regional. We had two that are current world leaders and over 1000 that will be ones in 2029. - Foster [more]
Unread 18-02-2013, 09:23
gamegeek1995 gamegeek1995 is offline
FRC #4701
gamegeek1995 is an unknown quantity at this point
Re: Shooter Programming Help
Originally Posted by Alan Anderson View Post
I don't see anything obviously wrong with what you're showing us. What does it do when you run it? What do you want it to do instead?
When the above code was put on the robot it just sort of lurched and then did nothing after that
We went back and loaded a fresh driver code with no modifications on it to check to see if maybe something happened to the robot but it worked fine with the unmoddified program
