Go to Post Things go wrong; it happens to the best of us. You learn from it and move on. - Waynep [more]
Unread 18-02-2013, 10:14
team4372 team4372 is offline
FRC #4372
team4372 is an unknown quantity at this point
labview adding button from joystick
Hello I am having a issues with adding a button into labview 2013. This is what i got so far in the programming I have no idea if this is even right thanks.
Name:	teleop false.PNG
ID:	14075  Click image for larger version
Unread 18-02-2013, 10:26
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
Re: labview adding button from joystick
Assuming you initialized the joystick in the begin vi (it is if you didn't modify the default code), it looks ok.
It looks like you are checking button 1 of the joystick. If it is true (ie pressed) you stop the motor, else false you pass the values from the axis to your motor.
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 18-02-2013, 10:30
FRC #4372
Precisely.Well the button works in the simulator and the motor stops but nothing is moving. Basically its for our launcher press button 1 and the 2 motor start and the drive motors stop.
Unread 18-02-2013, 10:51
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
It looks like you have the "drive motors stop" part, but you are missing "the 2 motor start" part.
Omar
Unread 18-02-2013, 11:01
FRC #4372
so do i add something like this?
Unread 18-02-2013, 11:09
Omar's Avatar
Try this.
Name:	labview adding button from joystick.png
Omar
Unread 18-02-2013, 11:10
Omar's Avatar
The part you added goes in your Begin.vi
Omar
Unread 18-02-2013, 11:20
Omar's Avatar
Add this to your Begin.VI
Omar
Unread 18-02-2013, 11:31
FRC #4372
would the buttons work in the simulator? and THe robot just spins in cercles in the simulator.
Unread 18-02-2013, 11:35
FRC #4372
here the begin and teleop updated
ID:	14081  Click image for larger version
Unread 18-02-2013, 11:41
FRC #4372
teleop true
Unread 18-02-2013, 11:48
Omar's Avatar
To use the 2 Motor Open with a Tank drive for your launcher.
Name:	Two Motor.png
Omar
Unread 18-02-2013, 11:56
FRC #4372
what value do i add in the false statement?
Unread 18-02-2013, 11:57
Omar's Avatar
In Teleop you need to rename the two "My Motor Refnum" to "shooter 1" and shooter2".
Be VERY careful with the Ref Names string! Pay attention to spaces you use in them.
"shooter2" is not the same as "shooter 2"
In fact make it a rule not to use any spaces. Call them "shooter_1" and "shooter_2"
I should have used "Launcher_Motor_1" and "Launcher_Motor_2" in my example that I posted.
Omar
Unread 18-02-2013, 12:02
Omar's Avatar
For the launcher motors? What do you want the launcher motors to do when you release the joystick button?
I assume you want them the stop when you release the joystick button as write out 0 (zero)
The snipplets that I posted you can copy them to your desk top and them drag them on to any block diagram and you will have the code just as I created it.
Omar
