Go to Post Our robot weighed 168lbs..... bring it on Trimspa!!! - slickguy2007 [more]
Unread 18-02-2013, 10:17
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
throttle
Can someone please help me out with programming a throttle in java/ When i press button 3 on Joystick 2 i want it to read the the throttle and adjust apply that speed to jaguar 3 and jaguar 4. Can you help? Thanks!
Unread 18-02-2013, 10:33
2185Bilal's Avatar
2185Bilal 2185Bilal is offline
Driver, Ld. Programmer, Electrical
AKA: Bilal Majeed
FRC #2185 (Ramazoidz)
2185Bilal will become famous soon enough
Re: throttle
here is the code
if(joystick2.getRawButton(3){
jag3.set(joystick2.getRawAxis(3)); jag4.set(joystick2.getRawAxis(3));
explanation:
first line(if button3 is pressed on joystick 2)
2nd line(then set the speed of jaguar 3 to the value from the 3rd axis of the joystick) - the reason why it is 3 is because the throttle axis is 3
3rd line(after that also set jaguar 4 to the same value)
RAMAZOIDZ
2009 Toronto West Regional - Regional Winners
2009 Waterloo Regional - Regional Winners
Unread 18-02-2013, 10:35
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Re: throttle
Ok thanks i will try that
Unread 18-02-2013, 10:37
2185Bilal's Avatar
AKA: Bilal Majeed
Thumbs up Re: throttle
no problem
btw, if you need any other explanation and help, do let me know
and ill try my best to help you.
RAMAZOIDZ
Unread 18-02-2013, 15:59
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Re: throttle
Ok so this worked a little. When the throttle is up then the jaguars dont run and when it is down the jaguars run very slowly. Is there more to it then what I have? Thanks.
