Re: labview adding button from joystick
so do i add something like this?
The part you added goes in your Begin.vi
Add this to your Begin.VI
would the buttons work in the simulator? and THe robot just spins in cercles in the simulator.
here the begin and teleop updated
#7
teleop true
#8
To use the 2 Motor Open with a Tank drive for your launcher.
#9
what value do i add in the false statement?
#10
For the launcher motors? What do you want the launcher motors to do when you release the joystick button?
I assume you want them the stop when you release the joystick button as write out 0 (zero) The snipplets that I posted you can copy them to your desk top and them drag them on to any block diagram and you will have the code just as I created it. |
#11
it works now i forgot to add the axis in the false statement
Thanks A LOT!! |
#12
In Teleop you need to rename the two "My Motor Refnum" to "shooter 1" and shooter2".
Be VERY careful with the Ref Names string! Pay attention to spaces you use in them. "shooter2" is not the same as "shooter 2" In fact make it a rule not to use any spaces. Call them "shooter_1" and "shooter_2" I should have used "Launcher_Motor_1" and "Launcher_Motor_2" in my example that I posted. |
