Go to Post How are you supposed to conceptualize without a complete grasp of what your trying to do? - Aren_Hill [more]
Unread 18-02-2013, 14:24
AquaMorph's Avatar
AquaMorph AquaMorph is offline
Alumnus of 2059
AKA: Christian Colglazier
FRC #2642 (Pitt Pirates)
AquaMorph is on a distinguished road
Gyro angle will not work with robot code
I am trying to get an angle from the gyro and I am able to get the sample code to work. But when I try to use the sample code on the robot code it just outputs a constantly increasing number from 0-360. I attached the code below. Can anyone tell me why this is happening?
ID:	14087  Click image for larger version
ID:	14088  Click image for larger version
FRC Drive: Play Store FRC Manager: Play Store
Unread 18-02-2013, 15:16
Re: Gyro angle will not work with robot code
You didn't set the gyro gain. Try this:
Unread 18-02-2013, 17:40
AquaMorph's Avatar
Alumnus of 2059
I copied your code and it is still constantly increase but this time by a smaller number.
Unread 18-02-2013, 17:46
The spec sheet for the gyro you are using should list a value for "voltage per degree of rotation per second", use the value they list for the gain.
When the cRIO is first booted, you know you must not touch the robot while the gyro initializes?
That's how it decides what zero is.
Unread 18-02-2013, 17:53
How small? Is it of the order of 1 degree every 2 minutes or so? If so, that would be normal drift for KoP gyro.
Unread 18-02-2013, 18:13
AquaMorph's Avatar
Alumnus of 2059
It is to the forth decimal place and moving the gyro doesn't do anything.
Unread 18-02-2013, 21:04
Post a photo of how you have it wired. Show both the gyro end and the other end of the cable. Please use the macro setting on your camera for close-ups.
Unread 19-02-2013, 08:11
AquaMorph's Avatar
Alumnus of 2059
I can't take a picture of it until tonight. However, I know the wiring is correct because I loaded the sample code on the robot and it ran fine and gave me the angles I wanted.
Unread 19-02-2013, 11:22
We should have asked you right at the start what was your intended use for the gyro.
I just saw on another thread that you are intending to use the gyro for your shooter altitude angle.
I think you want a potentiometer or encoder instead.
Unread 19-02-2013, 11:58
AquaMorph's Avatar
Alumnus of 2059
I think an encoder would work best. I don't think a potentiometer came in the KOP. Do you have an idea of what would be best for a shooter that is going to only moving up and down in a range of 70 degrees?
Unread 19-02-2013, 12:20
That's a great application for a potentiometer. An encoder would also work.
Unread 19-02-2013, 12:30
AquaMorph's Avatar
Alumnus of 2059
I don't think I have potentiometer but I can play with an encoder.
Unread 19-02-2013, 22:35
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
You must have a Radio Shack or Fry's somewhere near you. Get a 5K or 10K Linear Taper Potentiometer. They're cheap and easy to wire up and get working.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 20-02-2013, 09:21
mswalker mswalker is offline
FRC #2583 (Westwood Robotics)
mswalker is on a distinguished road
We have seen the constantly increasing gyro behavior which seems to be due to bad connections. Check that the connection to the analog board and the gyro itself are solid and don't have any wire "hairs" shorting. Also, as mentioned, check the datasheet for the gain. Our gyro (I think this year or last year KOP) has a gain of 0.007 instead of the 0.0125 of the examples.
http://team2583.org
Unread 24-02-2013, 12:52
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
http://www.chiefdelphi.com/forums/sh...42#post1239642
Please see this post, and see if this explains the issue.
The sooner we get behind schedule, the more time we have to catch up.
