Go to Post FIRST is not all about the robot, it's about the experience. Don't sour yours by whining about it later. - StephLee [more]
Unread 17-02-2013, 15:30
Hoogyme Hoogyme is offline
FRC #2852
Hoogyme is an unknown quantity at this point
How many servos can be powered off a single PWM terminal on the Sidecar?
I found this answer from 2009: http://forums.usfirst.org/showthread.php?t=11822
I'm wondering if this is still the case.
Unread 18-02-2013, 13:53
toastnbacon toastnbacon is offline
AKA: James
FRC #3169 (Saintborgs)
toastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the rough
Re: How many servos can be powered off a single PWM terminal on the Sidecar?
As far as I'm aware. One device per port tends to be the standard.
"This must be what going insane feels like."-Simon Tam, Firefly
Unread 18-02-2013, 14:07
I couldn't find a rule that explicitly ruled in one direction or the other.
R54 was the closest I could find:
Servos must be directly connected to the PWM ports on the Digital Sidecar. They must not be connected to motor controllers or relay modules.
Unread 18-02-2013, 15:01
Andy A. Andy A. is offline
Getting old
FRC #0095
Eric- is it correct to assume that the DC power pins on the PWM ports are all supplied by the same source? In other words, is there any performance difference between using a Y cable or separate ports for each servo (possible signal issues aside)?
Unread 18-02-2013, 15:11
Your assumption is correct. All of the 6V power pins are directly tied together with nothing separating them. Power wise, a Y-cable really shouldn't have a measurable* effect.
I haven't tested signal effects, but most servos are not opto-isolated and therefore don't consume measurable signal current.
* Assuming that extra cable length is 50mOhms and 800mA draw at stall, you losing 40mV above what you would with separate power pins, which amounts to less than a 1% performance difference - and this is an extremely conservative estimate. I would imagine that it would be swamped by measurement accuracy and part-to-part variability.
